Horsepower vs hill gradient problem
The discussion focuses on calculating the true horsepower output of a car when tested on a hill with a gradient of 12.8% using road dyno software. The software calculates power output based on gear ratios, total weight, and RPM, but yields lower readings on inclines due to additional energy required to overcome gravity. Participants suggest using the formula Power = mass * g * VC * Sin(theta) to determine the extra power needed for climbing, where 'g' is the acceleration due to gravity and 'VC' is the car's velocity. Accurate calculations require converting RPM to velocity and factoring in drag coefficients.
  • Understanding of basic physics concepts such as kinetic energy (KE) and gravitational force.
  • Familiarity with vehicle dynamics, including gear ratios and weight distribution.
  • Knowledge of road dyno software and its calculation methods.
  • Ability to perform trigonometric calculations related to slope angles.
  • Research the physics of vehicle acceleration and the impact of incline on power output.
  • Learn how to convert RPM to vehicle speed using gear ratios.
  • Explore advanced road dyno software features and their calculation methodologies.
  • Investigate the effects of drag coefficients and frontal area on vehicle performance.
Automotive engineers, car tuners, and performance enthusiasts looking to optimize vehicle power output measurements and understand the impact of hill gradients on dyno results.
donperry
So, I have a car I'm tuning using a road dyno software. This software basically uses the gear ratio of the car, it's total weight, and the speed it moves the RPM to determine it's power output (HP and Torque)
In order to use this software a flat road is needed. That works well and is very accurate compared to real dynos
My area doesn't have a road that long for tuning in higher gears, But there is a very long hill with a fixed gradient of 12.8%. If the test is done on this hill, unsurprisingly, the output from the software is much lower. How can I use this information to correct the output from the software.
EG:Hill of 12.8% grade reads 280hp
What is the true power if the road was flat?
Something doesn't seem right, unless the car is very high horsepower to weight ratio.
Welcome to PF!
You could use E=mgh to find the additional energy added during the climb. Then you have to divide it by time to climb to get the average added power. The problem is, if the speed isn't constant, you'll have to adjust for that, which isn't necessarily straightforward...
Also, do you know how this software does its calc? Is it timing the car's acceleration?
I think that's what he means by
That sounds like it's calculating angular acceleration as in...
Power = Torque * angular acceleration
Edit: opps that's wrong.
Thanks for the replies.
Yes, this software uses some formula against the speed of which the RPM climbs,
Each sample records the current RPM taken at that time
For example,
With gear ratios and wheel size factored in it then figures how much energy it would take to move the RPM of a vehicle up by 50 rpm (for example) in just 20 milliseconds with a total mass of 1500KG ,
The Kinetic Energy of the car is
KE = 0.5mV2
where
m=mass
V=velocity.
The KE gain is..
ΔKE= 0.5m (Vf2 - Vi2)
where
Vf is the final velocity
Vi is the initial velovity
So if you only know the rpm increase you can't calculate the energy required. That will vary depending on the initial velocity. eg it takes more energy to accelerate from 20 to 30mph than it does from 10 to 20 mph. Even though the velocity increase is the same in both cases.
You have to convert the initial and final rpm to initial and final velocity (using the gear ratio) before you do the subtraction to calculate the "increase" in rpm or velocity.
You can. The RPM is used to calculate the vehicle speed. They already know the mass.
They also factored in coefficient of drag and frontal area.
I was wrong for using "rpm change"
Energy is only used to overcome drag (in all its forms) and to accelerate the mass. Energy is not required to move the mass at a constant speed (if you ignore drag). So my guess is they only use the vehicle speed to calculate the drag.
The extra power required to climb a hill at constant velocity VC is given by..
Power = force * velocity
where in this case..
force = mass * acceleration due to gravity (aka "g")
velocity = VV = the vertical component of the cars velocity
VV = VC*Sin(theta)
where
"theta" is the angle of the hill and
VC is the velocity of the car
So putting that all together the extra power is..
Example:
The extra power required by a 1000Kg car going up a 10 degree slope at 5 meters per second...
= 1000 * 9.81 * 5 * Sin(10)
= 8517W
or
8517/750 = 11HP
thanks for that
  • · Replies 16 ·
  • · Replies 23 ·
11K
  • · Replies 32 ·
  • · Replies 17 ·
