How an Induction Stove Works Explained
  • Context: High School
  • Thread starter Thread starter TSN79
    Induction Works
The discussion centers around the functioning of induction stoves, specifically how they utilize magnetic fields to heat cookware while keeping the stove surface cool. Participants explore the principles of induction heating, its applications, and related industrial uses.
  • Exploratory, Technical explanation, Conceptual clarification, Experimental/applied
  • Some participants explain that induction stoves operate through induction heating, where a coil of wire generates a magnetic field that induces electric currents in the cookware, heating it.
  • One participant notes that the cookware must be made of conductive materials for the induction process to work effectively, while ceramics do not heat up due to their insulating properties.
  • Another participant mentions that induction heating can be powerful enough to melt metal containers, with food inside acting as a coolant.
  • Industrial applications of induction heating are highlighted, including its use in melting metals and precise heat treatment processes in the automotive industry.
  • Links to external resources and videos demonstrating induction heating in industrial settings are provided for further exploration.
Participants generally agree on the basic principles of how induction stoves work, but there is a range of applications discussed, particularly in industrial contexts, without a clear consensus on all technical details.
Some statements rely on assumptions about the properties of materials and the conditions under which induction heating is effective. The discussion does not resolve the specifics of how different materials interact with induction heating.
This discussion may be useful for individuals interested in the technical workings of induction stoves, applications of induction heating in various industries, and those exploring the properties of materials in relation to heat generation.
TSN79
Can someone explain to me how an induction stove works? I know it has something to do with magnetism, but how the casserole can get hot while the surface of the stove itself does not blows my mind!
Anyone?
Anyone?
In short, there's a coil if wire near the casserole pan. A current of electrons whizzes round in the coil and creates a field around it. When that field hits the pan it 'pushes and pulls' the electrons around inside the material it's made of. As the electrons in the pan get pushed and pulled around they heat up the pan, just like a piece of wire gets hot if you try to put too much current through it. That's why the pan has to be metal, or something else that's conductive, the coil has to be able to move the electrons around in things to make it hot. Because you don't want to have to plug in your pans to heat them up, the oven -couples- onto them with a magnetic field to achieve the same effect.
The coil doesn't care what is put in it so long as it can move electrons around. So ceramics won't heat up because they're excellent insulators, at room temperature anyway; a lot of the best superconductors are ceramics but need to be at cryogenic temperatures before they take on the weird properties of superconduction.
If you stove was powerful enough it could melt the metal containers you put on it. The food inside is acting like coolant, or radiator fluid, soaking up the heat from the metal.
Ovens just like your's, but much more powerful, are used industrially to melt metal. They're often used for metals that would be contaminated by normal flame heating or that need very specific cooking times and temperatures (annealing, meaning to soften, as well as tempering, to harden).
You can see some good video clips of induction heating being used industrially here;
http://www.ameritherm.com/videoindex.html (Notice how quickly the parts heat up)
The Precison Induction Heating video is the best to watch first. The rest are examples of the company's work.
We also use induction heaters to heat bearing assemblys before installation id the shaft fit is tight enough.
Induction heating is also extremely widely used in heat treating metals. A given alloy has an optimum temperature for hardening (and also for tempering). Induction heating allows for precise control of the temperature to which the metal is heated before quenching. This has allowed for automated, consistent, mass heat treatment of parts.
This has been particularly useful in the automotive industry. I once saw a figure for the number of different alloys of steel that go into the average car and was astonished. It was over a hundred, I think, each requiring heat treatment at a specific temperature.
  • · Replies 16 ·
  • · Replies 60 ·
