How and when to use Cauchy's integral formula
  • Thread starter Thread starter MissP.25_5
    Formula Integral
Cauchy's integral formula is used to evaluate integrals that fit its specific pattern, particularly when the contour may need to be closed for proper evaluation. The formula is applicable in various fields, including physics and signal theory. Accurate identification of the function f(z) and the point z0 is crucial for correct application. Handwritten work should be typed out for clarity, as attachments are often not reviewed. Proper formatting and clear presentation of the problem will facilitate better assistance from others.
MissP.25_5
Hello.
How do I know when to use Cauchy integral formula. Why do we use the formula in this question? As you can see in my attempt, I got stuck.
Are my values for f(z), z, z​0 here correct?
You got the right answer, since f(zo)=1.
You use the Cauchy integral when you have to evaluate an integral that matches the pattern of a Cauchy integral!
Sometimes, the contour needs to be closed to get a match and the integral on the closing path can be evaluated by some other means.
The Cauchy integral is very useful in physics and in signal theory.
No, I just solved it and f(z) is not 1, but 1/(z-1).
You proved that your integral is 2 Pi I * the Cauchy integral of f(z)=1 around z=I .
Therefore, your integral is 2 Pi I f(I) = 2 Pi I .
MissP.25_5 said:
Hello.
I never look at photo attachments of handwritten work; in fact, if you read the "PF Guidelines" post by vela, you will see that you are not supposed to use them except for very special circumstances---for several good reasons. You should take the trouble to type out your work if you want the helpers to take the trouble to offer free assistance.
Exactly! Thread locked. Please create a thread where you write out your work.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 16 ·
