How calculate propeller efficiency if I know propeller trust?
47 replies · 47K views · last reply
vissarion.eu
How calculate propeller efficiency if I know propeller trust ant motor power and motor efficienty?
convert thrust to watts (or any standardized unit of energy), motor output power is motor input power times efficiency, convert to the same standardized unit, Then thrust power divided by motor output power, and you have your propeller efficiency
You can't covert thrust to watts. Thrust is not power.
twasnow said:
convert thrust to watts (or any standardized unit of energy)...
How conwert thrust to watts?
Again, no.
Side: It's spelled convert.
Thrust is power and it is expressed as either Jules / Second, horsepower, Foot-pounds / Second, or of course Watts.
all of these are easily convertible.
Incorrect, thrust is expressed as a unit of force (e.g. Newtons, pounds force, etc.), not as a unit of power.
You need a speed to convert thrust to a power.
Please point us to ANY reference that lists thrust as a measure of power.
To answer the OP you need to know the aircraft speed to calculate the efficiency:
[tex]\eta_p = \frac{T*u}{P_{shaft}}[/tex]
where:
[tex]\eta_p[/tex] = propeller efficiency
[tex]T[/tex] = thrust
[tex]u[/tex] = aircraft speed
[tex]P_{shaft}[/tex] = shaft horsepower provided by the engine to the propeller
where:
Sorry, I have mis-spoke, While thrust is a force, without any motion there is no work being performed, if there is no work there is 0 efficiency so long as you are putting in ANY power.
So to correct, I assumed that by "I have thrust of the propeller" he meant, I have the thrust power, and it was expressed as such, other wise to calculate the efficiency we also need a speed giving us Nm/s a.k.a. Watts. Seeing as he is from Europe, has broken English, and didn't provide an air speed or say he was given that variable, I think my first assumption is probably correct.
None the less I shouldn't have repeated his mistake and called it "thrust" instead of "thrust power"
If it was expressed as a force than Great, it better have a speed along with it... well or a crazy slew of other variables so that a theoretical air speed can be calculated, fortunately due to the fact that we have "power in" we would not need to calculate the theoretical max power assuming no drag.
vissarion.eu we really need more info. what are the variables (at least as units) that you were provided.
where:
Oh and one other thing Mr. perfect, your calculation there provides the efficiency of a plane getting from point A to point B, Not the propeller efficiency.
Care to try again? I have 4 or so propulsion references on my desk right now plus a handful of places on line I can cite for the definition of propulsive/propeller efficiency. You are flat out wrong on all accounts.
How is your equation not about plane efficiency it is using aircraft speed
what if the propeller he is talking about is in a fan, or say a pump...[edited]
Because you don't use the word "thrust" to describe what a propeller is doing when it is powering a desk fan. "Thrust" means propelling an object.
Anyway, it only takes a relatively slight modification of that equation to change it to describe a desk fan.
where:
One horsepower is 745,69987158227022 W. Then, if motor is output power is 745,69987158227022 W, aircraft speed = 30 meters per second, trust is, then its fly what speed, 2 kilograms, propeller efficiency is:
(2 kg * 30 m/s) / 1 HP = 60 procents?
Be and not bad calculate propeller efficienty with following effect...:
http://img21.imageshack.us/img21/5701/orast.png
Then air created by propeller push plane to opposite direction than fly plane...
You have way, way, too many significant digits.
1 HP = 745.7W
Also, why did you use metric units, and then throw in HP? The denominator should be in watts.
Side: It's spelled percent. (No o, or s)
vissarion.eu said:
Be and not bad calculate propeller efficienty with following effect...:Then air created by propeller push plane to opposite direction than fly plane...
For reference, I have found it much better to google images rather than trying to draw them myself because you can usually find ones of higer quality. See:
I think how get propeller efficienty in practic is need that run two cars same weight. One powered wheels, second powered propeller. And what it runs in flat track without stops 30 km/h (kilometers per hour), who long 1000 kilometers. And look how many gasoline one car waste and second. If one car waste 70 liters gasoline and seconds (propeller powered) 100 liters. Then eficienty propeller is:
1/70 = 0,014285714285714285714285714285714
1/100 = 0,01
0,01 / 0,014285714285714285714285714285714 = 0,700000000000000000000000000035
0,700000000000000000000000000035 * 100 = 70 %
It's early and my brain hurts from a night of drinking.
Even in my lowered state of mental agility I can tell something about the above just doesn't seem quite right.
1. Why on Earth do you think at 30km/h a prop would give better fuel efficiency than driveshafts and wheels?
Run it with numbers the bother way around.
100 l for car and 70 l for prop.
Using the same equations you have, just flipped.
You get 142% efficiency. Wow.
2. Why do you think this is calculating the propellor efficiency?
3. What do you think the propellor efficiency acutally is, as you seem to be using a different definition to every textbook I've ever read on the subject?Look at what variables you have included in your 'calculation'.
Vehicle speed working axially to the prop.
Power output, from getting fom A to B to measure fuel useage.
Trust required to remain at set speed of 30km/h.
Compare the above to the equation that we know that works for prop efficiecnt that you dismissed.
1 HP = 745.7W
Because for me more simple use meters than feets or inches.
I not think that. Car with proppeller waste more fuel whan car driven with wheels.
Fair enough, I read it wrong (told you, my brain wasnt up to speed). The method you specified is still crap though.
I think there is little more to say on this, multiple textbooks disagree with you. Others have explained prop efficiency sufficiently well. Either you are dismissing it because you are stubborn or because you have a non standard definition of propellor efficiency.
You not good me understand. I not say 100 l for car and 70 l for prop. I say 100 l for propeller powered car and 70 l for normal car.
Aero car (propeller powered car):
Black and white photo of an early 1900s open-top car fitted with a large wooden propeller mounted at the front, with the registration LA 7235 on its side, surrounded by men in period clothing and caps on a cobbled street.
Two black-and-white illustrations of propeller-driven cars: left, a sedan with a large propeller mounted at the front; right, a low open car with a large fan-like wheel and propeller at the rear. Caption: THE AUTOCAR, IPC PRESS LTD., RUSS VON SAUERS.
Code:
How other?
Car powered propeller must be like normal car.
This car good:
Four black-and-white photos of a streamlined experimental car with a pusher propeller mounted at the rear, shown from several angles on a flat paved surface.
This car powered propeller not good for experiment, because is not like normal car:
Two photos of a dark, streamlined three-wheeled vehicle with a large ring-shaped propeller shroud at the front, shown in an outdoor setting with spectators in the background.
Your calculation is crap. The above post is similarly pointless to furthering your argument.
Fred showed you how to calculate prop efficiency.
/Thread.
If human pushing car and car not going, then human use 0 watts? No! It pushing in some power, it wasting energy, it do work. It power about 200 watts. Same and with propeller. If it pushing, but car not going, that's not mean, that it not have power. I think, hat possible convert trust to watts.
/Thread.
There you me put not enought details how calculate. I not understand.
For example car powered propeller have trust 100 kg.
It speed 30 km/h.
Motor output power 20000 watts.
What propeller eficienty?
if you are using the SI units.
Thrust in N
Speed in m/s
Power in Watts
You then put these numbers into the equation fred gave in post 9.
100kgf = 981N Thrust
30 kph = 8.33 m/s
Shaft HP = Rated motor output * mechanical efficiecny (assumre 90%)
For a car this value could be much much lower.
Power(shaft) = 18000 W
Efficiency = 981*8.33/18000
= .45
xxChrisxx said:
... Shaft HP = Rated motor output * mechanical efficiecny (assumre 90%)
I say motor output power. This mean not motor power, but output power, power, that motors gives. So power is not 18000 W, but 20000 W. Little mistake you make.
Efficiency plane without air resistance (or with air resistance?) = 981*8.33/20000 = 0,4085865. Efficienty car = 0,4085865 * 0.7 (friction to ground) = 0,28601055.
Efficiency plane with air resistance = 0,4085865 * 0,9 (for example if 0,4085865 is without air resistance) = 0,36772785.
Thanks!
