How can A be expressed in terms of n as a unit vector?
The discussion revolves around expressing an arbitrary vector A in terms of a unit vector n. Participants are tasked with showing a specific vector equation involving A and n.
  • Some participants attempt to break down the vector equation by considering the components of A and n, while others question the notation used for vector operations, specifically the use of "*".
The discussion is ongoing, with participants exploring different interpretations of the vector operations and attempting to clarify the notation. Some guidance is offered regarding the Cartesian components of the vectors.
There is a mention of assumptions regarding the coordinate system and the properties of unit vectors, as well as the need for clarity in notation for vector operations.
aigerimzh
Let A be an arbitrary vector and let n be a unit vector in some fixed direction. Show that A=(A.n).n+(A*n)*n
I know that (A.n).n gives component of arbitrary vector, assume that it equals to Ax
Most straightforward way is to write out the Cartesian components and verify. Just keep in mind that [itex]n_x^2 + n_y^2 + n_z^2 = 1[/itex].
Again, you have used "*". What is that? The cross product? The usual notation is just "AX B".
Yes, here also I mean (Axn)xn
You can set up you own coordinate system and so, without loss of generality, take n to be [itex]\vec{i}[/itex]. Write A as [itex]a\vec{i}+ b\vec{j}+ c\vec{c}[/itex].
Then [itex]A\cdot n= a[/itex] so that [itex](A\cdot n)= a\vec{i}[/itex]. What are [itex]A\times n[/itex] and [itex](A\times n)\times n[/itex]?
I think that (Axn)xn= aj?
No. Try again. What is Axn first?
  • · Replies 30 ·
