How can e^(1/z) be written using the definition of e^z?
The discussion focuses on expressing e^(1/z) using the definition of e^z, specifically for complex numbers where z = x + yi. Participants clarify that the variables x and y in the definition do not correspond directly to the real and imaginary parts of z but represent arbitrary values. The transformation involves using Euler's formula, leading to the expression e^(1/z) = e^(1/e^(iθ)) = e^(e^i(-θ)), which simplifies to e^(cos(-θ) + i*sin(-θ)). This approach provides a pathway to further manipulate the expression.
  • Understanding of complex numbers, specifically the form z = x + yi
  • Familiarity with Euler's formula: e^(iθ) = cos(θ) + i*sin(θ)
  • Knowledge of the properties of exponential functions in complex analysis
  • Basic skills in manipulating complex fractions and trigonometric identities
  • Study the derivation and applications of Euler's formula in complex analysis
  • Learn about the properties of complex exponentials and their graphical representations
  • Explore the implications of complex functions in calculus, particularly in contour integration
  • Investigate the relationship between complex numbers and polar coordinates
Mathematicians, physics students, and anyone studying complex analysis or seeking to deepen their understanding of exponential functions in the context of complex numbers.
filter54321
How do you write e^(1/z) in the other form?
z = x+yi
So we should be able to right it using this definition of e^z, no?
e^z = e^x * [cos(y) + i * sin(y)]
I pushed some numbers around the page for a while but I can't get 1/(x+i*y) to split into anything nice. Is there a trick?
...actually, I think I was confusing myself. The x,y in the definition don't have to be matching up with the x,y from the complex number z. The x,y in the definition correspond to the real and imaginary parts of an arbitrary complex z.Would you plug this into the definition?
real:
x/(x^2+y^2)
imaginary:
-y/(x^2+y^2)
real:
x/(x^2+y^2)
imaginary:
-y/(x^2+y^2)
simple answer no.
z=x+iy
[Re]z = x [Im]z = y
or z= cosq +isinq => eiq
if you look in your textbook you should have all the definitions necessary
e^(1/z)
z = x + iy = e^itheta = cos(theta) + isin(theta)
e^(1/z) = e^(1/e^itheta) = e^(e^i(-theta)) = e^(cos(-theta) + isin(-theta)) = ...
can you go from here?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 17 ·
