How Can I Build a Basic Transistor Amplifier for My Phone's Speaker?
5 replies · 2K views
ajbwarrrior
Hi,
I have a single 2 watt, 8 ohm speaker from an old radio that i wired directly to a headphone audio jack and tried it in my phone. as you can probably guess, my phones speakers are much louder.
How could i make a basic transistor amplifier that could give decent volume from the speaker?
I have seen many circuit diagrams for this but i don't know how a device would be connected to them.
Any schematics that would suit this application would be greatly appreciated.
You can do it with opamps, or discrete transistors. I'd recommend opamps. Just look at google images for audio amplifier IC and start reading about an approach. Note that amplifiers require a power source which can be as simple as a wall wart.
For example:
http://www.rason.org/Projects/icamps/icamps.htm
with the amp in the link, how would the input be connected to a 3.5mm auxiliary jack ?
The link shows a mono amplifier. The 3.5 jack has three rings, ground, left, and right. You would connect ground to ground and either left or right to the amp (or use a stereo IC with 2 amps). Or, you could make a resistive mixer where you connect both L and R to the input, each through, say, a 1K resistor.
I don't think that will work for what you are doing. It requires the proper DC levels on the input, and drives a continuous DC signal through the speaker when there is no signal. It is a pretty specialized hack for his radio application.
Look at this page --- Question 5 is probably the simplest design that will work, question 8 shows a 1 transistor approach.
http://www.allaboutcircuits.com/worksheets/trouble_bjtamp.html
The problem with the 1 transistor approach is that the speaker loads down the amp.
