How Can I Calculate Energy and Power for an 800W Electric Motor?
To calculate energy and power for an 800W electric motor, the key equations relate power, energy, and time, specifically Power = Energy / Time. The motor raises a load, gaining 24,000 J of gravitational potential energy in 120 seconds. To find the electrical energy supplied to the motor, one must use the power rating and time, while also calculating energy wasted and output power. Efficiency can then be determined by comparing useful output energy to input energy. Understanding these relationships is crucial for solving the problem effectively.
lovcullen
Energy Calculation ~~help
Question )
An 800W electric motor is used to raise a load. In 120s, the load gains
24,000 J of gravitational potential energy from the motor
Calculate :
a) electrical energy supplied to the motor
b) energy wasted by the motor
c) output power of the motor
d) efficiency of the motor
W=J/s
I have no idea //
i've got a big school exam next Monday T-T
help me~
thank you
Welcome to Physics Forums.
What is the equation that relates power, energy, and time?
You'll have to show an attempt at solving the problem before getting help (sorry, but that's our policy).
Power = Energy x Time
Energy = Power / Time
Time = Power / Energy
Is this right ??
Not quite, it's
etc.
Using that, can you find (a) the energy supplied to the 800 W motor?
Redbelly98 said:
Not quite, it's
etc.
AH~~~~~
now i got it ~:D thank you
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
