How Can I Determine the Equivalent Transfer Function of Two Active LTI Systems?
  • Context: Graduate
  • Thread starter Thread starter umarkhan
    Lti Systems
The discussion revolves around determining the equivalent transfer function of two active linear time-invariant (LTI) systems, G1(s) and G2(s), that operate at different times. Participants explore the implications of switching between these systems and the challenges in representing them with a single transfer function.
  • Debate/contested, Conceptual clarification
  • One participant, Umat, inquires about methods to derive an equivalent transfer function for two LTI systems that are active at different times.
  • Another participant suggests that since G1 and G2 are never active simultaneously, it may not be possible to describe the system with a single transfer function.
  • A different participant notes that switching between the two systems implies the joint system is no longer time-invariant, indicating that the situation is likely more complex than a straightforward combination.
  • Another participant agrees with the notion that a transfer function cannot be defined for a non-LTI system, suggesting alternative descriptions may be necessary.
Participants express differing views on the feasibility of deriving a single equivalent transfer function, with some agreeing on the complexity introduced by switching and the non-LTI nature of the combined system.
The discussion highlights the limitations of applying LTI system principles when dealing with systems that are not active simultaneously, and the implications of time-variance in the context of transfer functions.
Individuals interested in control systems, signal processing, and the theoretical aspects of linear time-invariant systems may find this discussion relevant.
umarkhan
hello,
If I have two LTI system in G1(s) and G2(s) and I know that for a certain fraction of the time period G1 is active and for the reminaing fraction G2 is active, then is there any method to get the equivalent transfer function ?
Umat.
I would think you would just have two transfer functions. Since there G1 and G2 are never active at the same time, you can't really describe it that way. At least, I don't think there is a way. Maybe I'm wrong though.
If you're switching between the two systems, the joint system is no longer time-invariant. It's probably going to be not so simple.
I agree with Manchot. And since you can't have a transfer function for a non-LTI system, you'll have to describe it some other way.
  • · Replies 0 ·
9K
  • · Replies 0 ·
