How can I get the intersection of these lines
The discussion focuses on finding the intersection of two lines defined by the equations y = x + 105.5 and a line with a negative slope. The user initially miscalculated the slope, using +1 instead of the correct -1, leading to an incorrect intersection point of -1.87. The correct approach involves substituting the accurate slope into the equation to find an intersection point that is less than -5.5. The key takeaway is the importance of correctly identifying the slope's sign in linear equations.
  • Understanding of linear equations, specifically the slope-intercept form (y = mx + b).
  • Knowledge of substitution methods for solving equations.
  • Familiarity with graphing lines and identifying intersections.
  • Basic algebra skills for manipulating equations.
  • Review the concept of slope in linear equations, focusing on negative slopes.
  • Practice solving systems of equations using substitution and elimination methods.
  • Learn how to graph linear equations accurately to visualize intersections.
  • Explore the implications of slope changes on the intersection points of lines.
Students studying algebra, particularly those working on linear equations and intersections, as well as educators looking for examples of common mistakes in slope calculations.
median27
Kindly view my 1st attachment. I need help to get the intersection of the highest line and the line extended by a slope from the horizontal line.
y=mx+b
y-y1=m(x-x1)
Kindly view my 2nd attachment.
By substitution, I always get the answer -1.87 which is obviously wrong. The answer should be lesser than -5.5.
Thanks in advance.
The first equation (y = x+105.5) is not quite correct. The gradient does have a magnitude of 1, however the line slopes downwards along the x-axis, therefore the gradient should be -1, not +1 as you have used. See if that fixes the problem.
thanks, i'll work on it
  • · Replies 22 ·
  • · Replies 16 ·
