How can I model a two tank system to control fluid level in tank 2?
The discussion revolves around modeling a two-tank system for controlling the fluid level in the second tank. Participants explore the dynamics of fluid flow between the tanks, the impact of disturbances, and the mathematical modeling of the system. The scope includes theoretical modeling, practical applications, and control strategies.
  • One participant describes the system setup, noting that tank 1 is larger than tank 2 and that the flow out of tank 2 is constant, seeking to maintain a constant level in tank 2.
  • Another participant suggests that to keep the level in tank 2 constant, the flow in from tank 1 should equal the flow out of tank 2.
  • A different participant raises considerations about differential pressure affecting flow rates, emphasizing the need for a control valve that adjusts based on feedback from the system.
  • Concerns are expressed about the impact of fluid height and valve opening on system performance, including losses due to piping and fittings.
  • A later reply discusses the modeling of the system as a second-order system, presenting equations for the rates of change of fluid heights in both tanks and seeking assistance with determining damping and gain.
Participants present various viewpoints on how to approach the problem, with some agreeing on the basic principles of flow balance while others introduce complexities related to pressure dynamics and system losses. The discussion remains unresolved regarding the optimal modeling approach and the specific parameters for control.
Participants express uncertainty about the mathematical modeling, particularly in determining the damping and gain of the system. There are also assumptions about the behavior of fluid dynamics that are not fully explored or defined.
KybKyb
Hello!
I'm currently working on a project where i am supposed to model a two tank system. The only information the project gave me, was that i have to control the fluid level in tank 2 (what kind of fluid
is up to me). I have tried to put the problem in a practical contex, where i have imagined a simplified water treatment process.
Water flows into tank 1, which i control. I'm assuming tank1 is bigger than tank 2. And there is a valve on the "connection" between tank 1 and tank 2 that i control. The flow out of tank 2 is constant and i do not control it.
The problem:
1) I want to find the water flow in, that allows for the fluid level in tank 2 to be constant, even with constant flow out.
2) Also, as a second problem, i want to simulate som disturbances in the water flow in, so that i am forced to use the water in tank 1 as a buffer (the goal is still to maintain a constant level in tank 2, while constant flow out)
Could someone help me/help get me started? Kinda new to this way of thinking, and I am finding it somewhat difficult.
Thanks in advance!
EDIT: fixed attached picture
Am I missing something? To keep the level in tank 2 constant, set the flow in from tank 1 equal to the flow out of tank 2.
I may have done a poor job of formulating my problem , sorry about that. I'm going to sit down and think this through, i see your point, its actually pretty simple :P
Here's a couple things to ponder:
1) As the water level lowers, the differential pressure will decrease between the water's surface (atmospheric) and the point just before discharge (if the valve were closed), causing a lower volumetric flow rate, thus filling the second tank slower than it would with a full tank.
2) If you want to maintain a constant flow rate, then in industry you would use a control valve which was programmed to open and close based on pressure (or volumetric flow) feedback from the system. Valves have what are called Cv curves, which tell you basically how much pressure loss you'll see for a given flow (the actual Cv, flow coefficient, value tells you how many gallons per minute of water will result in a 1 psi pressure drop through the valve at a given % open or setting)
As the flow rate increases, the fluid will see greater losses across the valve, decreasing the differential pressure and thus reducing the maximum theoretical flowrate (if you just used the simplified Bernoulli equation).
Additionally, the higher velocity of the fluid when the tank is full will cause more losses in the transfer piping and any other fittings (elbows, flowmeters, additional valves, etc) and further reduce the theoretical max. flow rate.
Basically, in designing a gravity system with constant flow rate, you'd have to consider all losses and the effect that all variables (i.e. fluid height, valve opening) will have on the system performance.
Thanks for the replies, and sorry for not answering, have been quite busy with the project. I have coupled the tanks a bit different, and the result was a second order system. I am struggling with findint the damping, and the gain of the system, based on the following equations:
dH1/dt=(1/(PA1)*(f_in-R1(H1-H2)
dH2/dt=(1/(PA2)*(R1(H1-H2)-(R2*H2)
R1, R2, 1/PA1 and 1/PA2 are just constants. f_in flows into the top of tank 1.
I'm not sure if I've bit of more than i can chew, I've found a approximation of the time constant simply by looking at the graph, but any help with the damping and gain would be appreciated :)
EDIT: fixed attachments
  • · Replies 26 ·
