How can i send a low amount of electricity through glass?
  • Thread starter Thread starter ianizaguirre
    Electricity Glass
The discussion revolves around the feasibility of transmitting a low amount of electricity through glass to power a small boat blade. Participants explore various methods and components that could facilitate this, including magnetic and light-based solutions, while considering design constraints such as size, power consumption, and cost.
  • One participant suggests using a rotating magnet on one side of the glass to induce movement in another magnet on the opposite side, noting this method is suitable for low power applications.
  • Another proposes using light as a power source, although specifics are not detailed.
  • A participant discusses the potential of creating a transformer with specific design considerations, including the challenges of transferring power across a significant gap.
  • There is a focus on minimizing the size and cost of the external components, with a target of under 8 watts and $25.
  • Some participants mention the concept of magnetic stirrers and their relevance to the proposed design, with one questioning the need for a custom stir bar versus using commercially available options.
  • A participant references a central heating pump that operates on similar principles, indicating that magnetically driven systems can be effective.
Participants express various ideas and approaches, but there is no consensus on a single method or solution. Multiple competing views remain regarding the best way to achieve the goal of transmitting electricity through glass.
Participants mention limitations related to power transfer efficiency, design constraints, and the need for further clarification on the specifics of the project. The discussion includes assumptions about the feasibility of different methods without resolving the technical details.
Individuals interested in experimental design, magnetic systems, or low-power electrical applications may find this discussion relevant.
ianizaguirre
there is A , B and C
A- is a small powered boat blade
B-is a piece of 1 to 1/2 inch glass
C- is the power (i don't know how it will power it yet)
So how is it possible to have a motor send electricity though the glass to power the small blade?
what would i need in C (like what parts) to get this to work?
Welcome to PhysicsForums!
Unfortunately, your ABCs are a little ill-defined (that's okay: it's part of the design process!)
Are we talking a little propeller in a small fish tank, or attempted propulsion of Wonder Woman's boat / submarine?
http://en.wikipedia.org/wiki/Invisible_plane
Is there any specific reason that traditional propulsion methods can't work for this application, or is this an exploratory sort of design? If the latter, you'll have to better narrow down the criteria and constraints and flesh out your points (also part of the design process).
A rotating magnet on one side could easily make another magnet follow its rotation - on the other side of a few mm of glass. Play with two magnets above and below a glass topped table to get the idea.
This only applies to low powers, of course, but, for a 'toy' / model, fine.
Light could also be used as your power source.
A sketch would probably help. The details really do count with something like this (is't called Engineering lol)
It all depends on the amount of power you want to transfer and the actual separation. It also depends on how bulky you can allow this to be.
You could make a transformer with a 'U' of transformer-type laminations on one side with the primary windings on and a similar 'U'on the other side with the secondary laminations. The problem would be that the primary inductance would be low and would take a lot of current. But you could get over this with resistance wire - assuming you didn't need to transfer much power. The problem is that 12mm is a huge gap for a transformer; that's why I reckon a magnetic / mechanical link could be your best bet, if all you need is to turn something.
i will see if i can do a sketch later on today but i would want the external piece to be as small as possible- using less than 8 watts of electricity, and at the end cost less than $25 in parts.
the shape of the external piece does not really matter as long as it is not really really bulky about the size of a little less than 1/2 a small water bottel on part C would be ideal
Search for "magnetic stirrer" parts on eBay.
Is this for fresh water?
Also, might this be a proprietary patentable invention? One where you can't just supply every detail?
Aircraft warning lights on AM broadcast towers are powered across a yards-wide gap using a pair of hoop-shaped coils. If coil diameter is much wider than the glass thickness, then you've made an air-core transformer. Much field leakage though.
That's pretty much a magnetic stirrer, with a fancy flea (the stir bar) and a little housing. Assuming there's a gap between the magnet and the propeller, you can probably move some air with it.
EDIT: Courtesy of Instructables.com: how to build your own magnetic stirrer:
http://www.instructables.com/id/Magnetic-Stirrer/
Still only half the problem since you need to build a customized stir bar.
why do i have to build a custom stir bar? can't i just order one off the 50 shape stirbars from a website and attach the stirbar with hot glue to the blades of a computer fan (side A)? and then have a small electric motor in side C with a magnet attached to the tip of that motor? will this work?
but here is a link to a pump i found that functions on the same idea that i want to do
My central heating pump works on this principle and develops significant power. Magnetically driven impellers across a flexible membrane have been used in plumbing for decades.
thats great news , i need someone who can really guide me about doing this project. i will be going the magnetic route with the stirer idea.
12K
