How Can I Solve This Integral Using u-Substitution?
  • Level: Undergrad
  • Thread starter Thread starter nick.martinez
    Substitution
10 replies · 2K views
nick.martinez
∫1/(10p-p^2)dp
i tried using the u of substitution but for some reason I am unable to isolate dp and get an equation in terms of du which i could then plug into the integral and take the antiderivative.
Since there is a p2 in the denominator, the first thing that comes to mind is
[tex]\int \frac{1}{1 + p^2} \, dp = \arctan(p)[/tex]
So I would try completing the square, i.e. write it as
[tex]k \cdot \int \frac{1}{1 + u^2} \, du[/tex]
where u = (p + a) / b.
not quite sure where you got u=(p+a)/b
do you mean i should factor out a 10 from denominator which would give me:
(1/10)∫1/(p-(p^2)/10)dp
By the way, I was assuming that you know the arctan integral. If not, you could try splitting fractions, i.e. writing
[tex]\frac{10p - p^2} = \frac{A}{10p} - \frac{B}{p^2}[/tex]
I would like get this into a Ln function instead of using arctan
are you using a partial fraction decomp in this case. if so that would be my preferred choice at getting to a solution.
CompuChip said:
No, start by writing 10p - p2 as (p - a)2 + b.
when i find the perfect square how do i find what the perferct square would be. I don't even know where to start. i punched the problem into wolfram and it completed the square of denom by turning
1/(10p-p^2) which i guess is equal to 1/(25-(x-5)^2), how do i do this?
OK in that case first try with the partial fraction decomposition, once you have arrived at the solution I will show you the method I was thinking of initially for completeness.
I'm sure you mean
$$ \frac{1}{p(10 - p)} = \frac{A}{p} + \frac{B}{10 - p}$$
