MATLAB How can I troubleshoot problems with fsolve in MATLAB?
  • Thread starter Thread starter La82
    Matlab
The discussion revolves around troubleshooting issues with MATLAB's fsolve function. The user, a MATLAB beginner, initially encounters an error stating that the function 'lambda_y1' is unknown when attempting to solve a set of equations. The solution involves correcting the syntax for fsolve by ensuring that the function is called with the appropriate initial guesses and that all constants are defined within the function itself. After implementing these changes, the user faces a new challenge where fsolve indicates that no solution is found, suggesting that the function values are not close to zero. The advice given includes verifying the equations with known values and simplifying them to identify potential issues. Debugging is recommended to improve the chances of finding a solution.
La82
Hi everyone,
I am a MATLAB newbie and am having some problems getting fsolve to work. I tried using the example given in the help section but it keeps saying that my function (lambda_y1) since that is the first one it finds is unknown.
My functions are generated like this (sorry for the messy notation):
function F = myfun(lambda_y1,lambda_y2,h_1,h_2,F_c1,F_c2)
F = [g_1+607200.*lambda_1.^3-1899000.*lambda_1.^2+1976400.*lambda_1-684600;
g_2+607200.*lambda_2.^3-1899000.*lambda_2.^2+1976400.*lambda_2-684600;
lambda_y1.^2.*(4.*h_m1.^2+y_01.^2)-(4.*(h_m1-h_1).^2+(lambda_1.*y_01).^2);
lambda_y2.^2.*(4.*h_m2.^2+y_02.^2)-(4.*(h_m2+h_2).^2+(lambda_2.*y_02).^2);
F_c1.^2.*(4.*(h_m1-h_1).^2+(lambda_1.*y_01).^2)-16.*g_1^2.*(h_m1 - h_1).^2;
F_c2.^2.*(4.*(h_m2+h_2).^2+(lambda_2.*y_02).^2)-16.*g_2^2.*(h_m2 + h_2).^2];
I call it like this:
x0=[0.5,0.5,0.0005,0.0005,0.1,0.1];
f = fsolve(@myfun,x0,lambda_y1,lambda_y2,h_1,h_2,F_c1,F_c2);
All the constants except for the unknowns are given earlier.
Can anyone help me get this to run?
Lonnie
What are the unknowns you are trying to find?
First of all the syntax which you are using is not correct,
most common and simple syntax is "f = fsolve(@fun,x0)", where x0 are the initial guesses.
In your case also i guess x0 are the initial guesses, the correct syntax should bex0=[0.5,0.5,0.0005,0.0005,0.1,0.1];
f = fsolve(@myfun,x0);Also, the myfun should like as follows:
it should initialize all the unknowns with their initial guesses i.e.
unknown1 = x0(1);
unknown2 = x0(2);
and so on,
also you should define all the values of the constants inside the myfun itself.
Constant1 = a;
Constant2 = b; etc.
I guess it will solve the problem.
Hi again,
Yep that did it, thanks alot, but now I have run into another problem. I run my equations and get the following stopping criteria:
No solution found.
fsolve stopped because the problem appears regular as measured by the gradient,
but the vector of function values is not near zero as measured by the
default value of the function tolerance.
I get that there must be a problem with my equations, but I have no idea what to look for!
Lonnie
As you think, may be there is some problem with your equations, then it will be better if you check them with some known values, see if it is giving correct result.
(Also there may be the case that there is "no solution", which i think is not the case, if you are expecting some solution)
Also it will be helpful if you simplify the equations.
You will have to debug it...and see if there are any improvements.
