How Can the Relative Speed of Photons Exceed the Cosmic Speed Limit?
The discussion centers around the concept of relative speed between photons and whether it can exceed the cosmic speed limit of light. Participants explore the implications of special relativity on the perceived speeds of photons approaching each other, examining definitions of relative speed and closing rates from different reference frames.
  • Some participants question the meaning of "relative speed" for photons, noting that there is no reference frame in which a photon is at rest.
  • Others argue that the distance between two photons can shrink at a rate greater than the speed of light when viewed from a stationary observer's frame.
  • One participant asserts that special relativity only prohibits speeds exceeding the speed of light when viewed from another object's reference frame, not for two objects moving towards each other.
  • Several participants discuss the concept of "closing rate" versus "relative speed," emphasizing that they are not the same and that closing rates can exceed the speed of light without contradicting relativity.
  • There is a claim that the relative speed of one photon with respect to another is undefined, as photons do not define a reference frame.
  • Participants express confusion over how the distance between photons can shrink while adhering to the cosmic speed limit, leading to further inquiries about the nature of speed in relativistic contexts.
Participants do not reach a consensus on whether the relative speed of photons can exceed the speed of light. There are multiple competing views regarding the definitions of speed and the implications of special relativity.
Participants highlight limitations in understanding how speeds add in relativistic contexts compared to everyday experiences, indicating a potential gap in intuitive grasp of the concepts involved.
The fallacy is here is the mention of a "relative speed" for photons without defining what exactly you mean by "relative speed". It depends on what you mean by that. If you mean by relative speed "the speed one object sees the other object moving at", then this is a non-question because there exist no reference frame in which a photon is at rest.
If you simply mean "how fast does the distance between the two objects shrink as measured by a 3rd, stationary observer", then the answer is the obvious 6*10^8m/s.
@Matterwave yeah it means for a 3rd, stationary observer, but the distance between two objects shouldn't shrink faster than 3*10^8m/s. The exact question is why/how here for a stationary observer, the photons are moving towards each other with a speed more than the cosmic limit?
Who said that the distance between two objects can't shrink faster than 3*10^8 m/s? Special Relativity certainly doesn't say that.
Special relativity says only that one object can never exceed a speed of 3*10^8m/s as viewed from another object's reference frame. It makes no claims for two objects working together.
You just tell me, isn't in this case, one photon approaching another photon(opposite one) with a speed equal to 2c? Which is more than the cosmic limit, how is this in agreement with the theory of relativity, that is what I want to know!
As far as I know speed=dx/dt, so according to this definition how is this 'shrinking of distance between the two objects' different from 'speed'? Isn't rate of shrinking of distance between two objects, what we call 'approaching speed'?
The "cosmic speed limit" applies to objects with mass relative to an inertial frame.
Instead of photons, imagine two massive objects approaching each other. Each object has a speed of 0.99c relative to the observer between them. This observer can calculate that the distance between the two objects, in his reference frame, is shrinking at 1.98c. This does not contradict the "cosmic speed limit", because the speed of one of the objects relative to a reference frame in which the other object is at rest is not 1.98c: it is about 0.9999c (calculated using the relativistic formula for adding velocities).
Instead of photons, imagine two massive objects approaching each other. Each object has a speed of 0.99c relative to the observer between them. This observer can calculate that the distance between the two objects, in his reference frame, is shrinking at 1.98c. This does not contradict the "cosmic speed limit", because the speed of one of the objects relative to a reference frame in which the other object is at rest is not 1.98c: it is about 0.9999c .
I understand that the speed of any of the two massive objects w.r.t observer will be 0.999c but when we see from frame of reference of any of the moving objects the speed of the other object w.r.t it will be 1.98c which is more than the cosmic limit.
P.S. As far as I have understood speed is always relative(correct me if I am wrong).
Reread Michael C's post. The speed of one object with respect to the other is not 1.98c.
The 1.98c is the closing rate as seen by the third frame. It's not the speed of anything.
Micheal C talks about a reference frame in which the other object is at rest, but I am talking about reference frame when both the objects are moving. I am talking about the reference frame in which both the objects are moving and I am taking into account the speed of one of the object with respect to other!
Realize that those two statements contradict each other. When you talk about the speed of object 2 with respect to object 1, you are talking about the speed of object 2 in a frame in which object 1 is at rest. That's what 'relative speed' means.
The problem (I suspect) is that our everyday intuitions about how speeds add, which are based on objects moving much slower than light speed, do not work when speeds are higher.
For example: If two cars move towards each other at 60 mph with respect to the earth, then their relative speed is (pretty close to) 120 mph. Not true when objects move at significantly close to light speeds.
Yes, as already stated, the closing rate (being the rate of change of the distance measured between the two objects) as seen by the observer in this frame is 1.98c. That is not the same thing as the speed of one object with respect to the other one.
The fact that "closing rate" and "relative speed" are not the same is certainly a surprise when you start studying relativity, since it contradicts our everyday intuition, but it is in fact completely logical.
Just now want to know one thing.Is the relative speed of one photon wrt other is greater than c or not?If not then why and how the distance is shrinking the other way?
The speed of one photon relative to another one is undefined, since a photon does not define a reference frame. You can replace the photons by objects traveling as near to the speed of light as you wish (see my example above): their relative speed will never be above c.
I must once more stress this point: "closing rate" and "relative speed" are not the same thing. A closing rate of more than c does not contradict the theory of relativity.
...The speed of one photon relative to another one is undefined, since a photon does not define a reference frame.
This is accurate, but it should also be noted that if you were traveling really, really close to lightspeed, .9 or .99 or .999c, light would still go buzzing by at 'c'. Light zips by a massive observer at 'c' no matter how fast that observer is moving. Everybody sees light at speed 'c'.
jtbell said:
Look up relativistic "velocity addition":
http://hyperphysics.phy-astr.gsu.edu/hbase/relativ/einvel.html
Velocity addition doesn't really apply here because photons don't have a rest frame. However, setting u,v=c does yield a velocity c.
Photons don't have a rest frame, so asking about the speed of one photon relative to another doesn't have any real meaning.
Please could you tell me what would be the speed of projectile fired from #1 relative to #2. I tried to solve it using the given equations, but I think I got some error!
Detailed solution will be much welcomed and appreciated.
Thanks.
Show us how you tried to do the calculation, and someone will probably be happy to point out your error.
My calculation is as following:
The speed u'(speed of projectile w.r.t to #1) in this case=0.7c, then I calculated u(speed of projectile w.r.t stationary observer) by u=0.8c+0.7c/1+0.8c*0.7c/c^2, then I calculated the relative speed of projectile w.r.t #2 by the same equation u''(#2)=u+0.9c/1+0.9c*u/c^2
Is absolute rest frame(as you mean here that the object 1 is at rest) possible in this universe, I think each and every object in this universe is moving with respect to one or other reference frame.
Does relative speed truly mean that other body should be at rest, I think we incorporate in this term i.e. relative velocity when both the bodies considered are moving, as far as I know when one of the bodies is at rest with respect to other then we don't use the term relative velocity.
Thanks for the info, would you please give us more info on the difference on closing rate and relative speed and how they are different, or guide me to a place where I would find such info on it.
Thanks.
Every object is at rest in its own rest frame. That's what 'rest frame' means. Nothing absolute about it.
Everything is always at rest with respect to itself. So the relative velocity of something with respect to me (say) means the speed it has in a frame in which I am at rest.
Looks OK to me.
Thanks.
Have a look at the wikipedia article on Faster-than-light, "closing speeds"
See also the paragraph on third party observers on this page: Is Faster-Than-Light Travel or Communication Possible?.
The cosmic speed limit says that [itex]|\frac{dx_i}{dt}|<c[/itex] where [itex]x_i[/itex] is the position of some given massive object, i, in some given inertial reference frame. This does not imply that [itex]|\frac{d(x_i-x_j)}{dt}|<c[/itex]. Do you see that those are entirely different quantities?
[itex]|\frac{dx_i}{dt}|[/itex] is used when reference frame is at rest, so we define change in position of object w.r.t to that reference frame by it, but we are talking about a situation in which both the objects are moving and we use one of the objects as reference frame for other, so how will you define the change in position w.r.t to reference point in this case, certainly not by "[itex]|\frac{dx_i}{dt}|[/itex]", as both the objects are moving in which we use one as reference frame.
Remember that "at rest" has no meaning in an absolute sense: you can only say that something is "at rest" with respect to something else. You use the phrase "when reference frame is at rest". This phrase as it stands has no meaning.
This is unclear. You say "as both the objects are moving". Once we have used one of the objects to define a reference frame, that object is not moving in the defined reference frame.
This is a self-contradictory statement. If both objects are moving then neither is being used as a reference frame for the other.
If you want to use one object as the reference frame for the other then you must transform to a reference frame where the reference object is stationary, not moving.
Either I am not able to express or you aren't getting my point! Now I will use an example to explain the situation which I am trying to define:
Suppose the distance between two missiles A and B is decreasing in space(there is nothing except these two missiles) and you are sitting in one of the missiles. Now my question is how will you define motion here, how can you say whether A is moving towards B or B is moving towards A, whether only A is moving or whether only B is moving or both are moving? And how will you define reference frame here?
It is equally valid to say that A is moving towards B as it is to say that B is moving towards A. We cannot say in an absolute sense that one of the missiles is "moving" and the other is "at rest": we can only say that there is relative motion between the missiles.
If I am sitting on one of the missiles, then it would be simplest for me to use a reference frame in which I am at rest. Let's say I'm sitting on missile A. For me, A is at rest and B is moving. For my friend sitting on missile B, B is at rest and A is moving. We describe the situation differently, but both of us are right.
Note that I say "it would be simplest for me to use a reference frame in which I am at rest". I don't have to use this frame of reference. I could also define a frame in which both A and B are moving. The basic principle of relativity is this: all of these reference frames are equally valid. There is no single frame that tells us what is "actually" happening: any frame describes what is actually happening just as well as any other.
  • · Replies 35 ·
  • · Replies 45 ·
