How Can We Make 100! Divisible by 12^{49}?
  • Context: Graduate
  • Thread starter Thread starter Gokul43201
    Game
The discussion revolves around the mathematical problem of determining the least number that must be multiplied to 100! to make it divisible by 12^{49}. The conversation includes number theory concepts, factorials, and divisibility conditions.
  • One participant poses the question about making 100! divisible by 12^{49} and requests a brief explanation with the answer.
  • Another participant suggests a multiplication of 1/(99!*50), which is challenged as incorrect.
  • Several participants calculate the factors of 2 and 3 in 100!, concluding that it has 2^{97} and 3^{48}.
  • It is proposed that multiplying by 6 (2^{98-97} * 3^{49-48}) would suffice to achieve divisibility by 12^{49}.
  • A later reply suggests that the correct answer is actually 12^{49} / 100!, which is significantly smaller than previous suggestions.
  • There is a discussion about the assumptions regarding whole number solutions in mathematical problems, with some participants noting the expectation of positive integers in the context of divisibility.
  • Another participant introduces a new question related to matrix theory, specifically about nilpotent matrices and their properties.
  • Various approaches to proving nilpotency are discussed, including the implications of the trace of a matrix and its eigenvalues.
Participants express differing views on the correct answer to the original problem, with no consensus reached. There is also a debate about the assumptions made regarding the nature of the solutions (whole numbers vs. rational numbers).
Participants note the complexity of the problem and the need for careful consideration of mathematical definitions and assumptions, particularly regarding divisibility and the nature of solutions.
This discussion may be of interest to those studying number theory, factorials, and matrix theory, as well as individuals exploring mathematical problem-solving and reasoning.
  • #241
If a group G is the set theoretic union of a family of proper normal subgroups each two of which have only the identity in common, then G is abelian.
Mathematics news on Phys.org
  • #242
very hard question but its interesting to solve, i will try it.
  • #243
There are 50 factors of 100 divisibile by 2, 25 by 4, 12 by 8, 6 by 16, 3 by 32 1 by 64 so the power of two in 100! is 97.
similiarly there are
33 div by 3, 11 by 9, 3 by 27 and 1 by 81 making 48 times 3 divides, so i guess
2*3^50 will do
  • #244
Let X be normal, let a_1, a_2, ..., be in X, and let A = {a_1, a_2, ...}. Show that the following are equivalent:
I. No a_i is a limit point of A.
II. There is a continuous function f: X -> [0,1] such that f(a_i) = 1/(2^i) for all i.
  • #245
Let f be holomorphic on the unit disc.
a) If f(x,y) = u(x) + iv(y), what can you say about f?
b) If [itex]f(x,y) = \phi_x + i\phi_y[/itex] for a real function [itex]\phi[/itex], what can you say about f?
  • #246
Unless I'm missing something, the center can non-trivially intersect at most one of the normal subgroups. If it didn't, then either the center is trivial or two of them have more elements in common. Either way, how can G be abelian? Unless there were only one...
  • #247
Let the normal subgroups be labeled [itex]G_i[/itex] where [itex]i \in \mathcal{I}[/itex]. Suppose that [itex]a \in G_i, b \in G_j,\ i \neq j[/itex]. Then by the normality of G_i and G_j, [itex]aba^{-1}b^{-1}\in G_i \cap G_j = \{e\}[/itex], so [itex]aba^{-1}b^{-1}=e[/itex] and thus a and b commute.
Now, suppose that [itex]a, b\in G_i[/itex]. Since G_i is a proper subset of G, we have that there is some element [itex]c \in G \setminus G_i[/itex]. Let G_j be the normal subgroup containing c. By the previous paragraph, c commutes with both a and b. Consider the elements ac and bc. If these elements commute, then we have abc² = acbc = bcac = bac², and so ab = ba. So now suppose that ac and bc do not commute. Then by the first paragraph they must both lie in a common subgroup G_k. If k=i, then we would have both a and ac in G_i and hence [itex]c\in G_i[/itex], which contradicts our choice of c. So k≠i. But then [itex]ac(bc)^{-1} = acc^{-1}b^{-1} = ab^{-1} \in G_k \cap G_i = \{e \}[/itex], so [itex]ab^{-1}=e[/itex] and thus a=b, so a and b trivially commute. Thus G is abelian.
  • #249
The statement that "since there are an infinite number of circles in fig. 1 and fig. 3 the total area of all circles of both figures approach equality" is blatantly false. The total area of the circles is not even close to being equal in fig. 1 and fig. 3.
  • #250
Care to explain?
  • #251
Niivram said:
Care to explain?
I wouldn't expect Citan to explain, as this looks very similar to the https://www.physicsforums.com/showthread.php?t=450364" thread.
Citan is correct, point 2 is false. And I'm not even a mathematician. As a matter of fact, I cannot understand a single thing in this entire thread, except that point 2 is false.
  • #252
Yeah, I'm convinced that Point 2 is wrong. But I'm still confused. You're saying, if you have an infinite number of small circles, and an infinite number of big circles, the area isn't the same right?
  • #253
As I said, I am not a mathematician, and got way over my head linguistically in the troll physics thread. I will not make the same mistake again.
I also believe you've broken the rules of the thread:
Gokul43201 said:
A Q&A game is simple: One person asks a relevant question (it can be research, calculation, a curiosity, something off-the-top-of-the-head, anything ... as long as it's a math question) and other people try to answer. The person who posts the first correct answer (as recognized by s/he who asked the question) gets to ask the next question, and so on.
Let me start this off with a simple number theory problem :
What is the least number than must be multiplied to 100! (that's a factorial) to make it divisible by [itex]12^{49}[/itex] ?
(throw in a brief -couple of lines or so- explanation with the answer)
You need to answer the last question before you can ask your own.
And I'm afraid I'm going to have to unsubscribe from this thread. I read the post(#247) before your original, and can't figure out if it's a question or an answer. :bugeye:
Ciao!
  • #254
hehe, Never thought of the rule : D. Sorry.
Ciao!.
  • #255
Gib Z said:
O well since I guess I got the last one, I'll just ask again what post 169 asked: How can one find the surface area of a ring?
What do you mean by a "ring"? A torus?
  • #256
I may have, but I have a better question now.
If [itex]a_n[/itex] is a monotone decreasing sequence such that [itex]\sum a_n[/itex] converges, show [itex]na_n \to 0[/itex], and then make the generalization that a measure theorist would make.
  • #257
Well, the proof is quite easy: We must have [itex]a_n\ge 0[/itex] for all [itex]n[/itex], for otherwise we would have a series in which all but finitely many terms are smaller than some fix negative number, and then the series would diverge to [itex]-\infty[/itex]. Assume, to get a contradiction, that [itex]na_n \to 0[/itex] does not hold. This means that there is an [itex]\epsilon>0[/itex] and arbitrary large [itex]m[/itex] such that [itex]ma_m\ge\epsilon[/itex].
Now, there is an [itex]N[/itex] such that [itex]\sum_{n=N+1}^\infty a_n <\epsilon/2[/itex]. Then, we can choose an [itex]m\ge 2N[/itex] such that [itex]ma_m\ge\epsilon[/itex]. Since [itex]a_n[/itex] is monotone decreasing, it folllows that [itex]a_n\ge\epsilon/m[/itex] for all [itex]n\le m[/itex]. Hence, [itex]\sum_{n=N+1}^m a_n\ge (m-N)\epsilon/m \ge\epsilon/2[/itex], which is a contradiction. Thus, [itex]na_n \to 0[/itex].
Generalization? The only one that comes to my mind is: Let [itex]\mu[/itex] be a positive measure on the real interval [itex][a,\infty)[/itex], ant let f be a [itex]\mu[/itex]-integrable on [itex][a,\infty)[/itex] (i.e. the integral over the entire interval is exists and is finite) and monotone decreasing. Then [itex]xf(x)\to 0[/itex] as [itex]x\to\infty[/itex].
  • #258
Niivram said:
Care to explain?
The sum of the areas of the circles in figure 1 is bounded by the area of the triangle containing them, which is obviously far less than the area of the central circle in figure 3. You could probably show that the areas of the triangle in fig 1 and the squares in figs 2 and 3 are the least upper bounds for the summed areas of the circles in those respective figures, thus...
fig 1 < fig 2 < fig 3
  • #259
I got a challenge for you... This question is answered in two different ways from two different professionals with different backgrounds. I asked a Physics Professor and a Mathematics Professor a question and got two different answers. But, isn't it true there is only one truth in answering a simple question such as this one? Here it is- if I take a distance or an object and cut it perfectly and half, then take one of those halves and cut it perfectly in half, again. And repeat this over and over again. What will happen eventually to the distance or thickness of the object ? The reason I brought this to your attention is because it appears that you pride yourself and/or you have a good understanding of physics, I am assuming. Good luck, I would love to hear your response to this question.
  • #260
Inventor, what do you mean with "eventually"? Do you mean that you actually cut an infinite number of times, or just that you cut a finite, but arbitrarily large number of times?
  • #261
Can you elaborate? The question is very unclear, which may explain why you received two different answers. What do you mean by "what will happen to the thickness of the object"? Are you asking what will happen if you halve its length an infinite number of times?
  • #262
nothing, it remains the same..it`s a question similar to the question "which is heavier?" a kilo of cotton or a kilo of nails..lol
  • #263
Definitely not. Most "simple questions" tend to be the hardest because the terms used are open to interpretation.
A more interesting problem would be catalog as many possible answers as we can think of!
  1. An infinite number of divisions of space ("distance") is possible, and the limit is zero.
  2. You are dividing space, but don't have infinite time, so it is impossible.
  3. You are dividing space, and have infinite time, but you can't divide smaller than Plank's distance.
  4. You take shorter time with each subdivision and you can divide Plank's distance, but you can't observe it. So it is moot.
  5. You are dividing a physical object. You can't divide subatomic particles.
  6. Heck, you can't divide an atom perfectly either.
  7. You can't do perfect division, full stop. The question is meaningless.
  • #264
Hello "pwsnafu". I see that you pretty much understood what I was asking. I was asking the question using two different scenarios. Cutting a distance in halves until there's nothing left, if possible OR cutting on object in halves until there is nothing left, if possible. Well, you explained it well that by cutting a PHYSICAL object in half over and over again you will eventually get down to subatomic particles which apparently are impossible to cut in half, again physically. I also agree with you when you said "An infinite number of divisions of space is possible, and the limit is zero.". I agree with you 100%. But, why is it so difficult for so many other people including so-called professionals to answer the question properly when I was referring to DISTANCE being cut in half over and over and over and over again, without putting a limit on how many times you can do it over and over. I had to word it that way and if I worded it differently such as saying "over and over, what will happen eventually" it leads people to assume there is an end conclusion which leads them to say "you will run out of space", which I know is absolutely incorrect. That is why I asked the question the way I did but there may have been a better way to ask it. The two persons whom left the other posts above yours agree with that, apparently. It was at Davis, California University where I had asked a Physics and Mathematics Professor the question. And when I asked the two professors the question I used ONLY the scenario using a space or distance and NOT on object. The physics professor responded to my question by saying "Yes, you will run out of space and the two objects will touch each other." Why did he answer the question that way, word for word. Keep in mind I asked if you have two objects and referring to the distance between the two objects that are coming closer to each other. I could not have been more specific to what I was referring to when I asked that Davis University Physics professor. But, I had waited about one half hour for the mathematics professor to return to his class on the campus to ask HIM the exact same question. He responded and said "The two objects will never touch each other no matter how many times you cut the distance between the two objects in half." I would love to see both of those professionals in the same room and at the same time discussing their reasoning for reaching their conclusion to each other! Again, believe me, I did ask both those professors the exact same question using the exact same words. I already knew the answer to my question but, I'm just trying to make some sense out of why I got two completely different answers. I guess sometimes the smarter we think we are, that is assume we are, the more sloppy we get at answering the most basic simple questions that are somewhat easy to answer. With all the above being said and realized, I guess there is another way to share the thought of what happens when you cut a space between two objects over and over continuously and here it is: "There is a way to prove how you can take two objects and make them move toward each other for an eternity but they will never touch each other!" It's called MATHEMATICS. Meaning it can be proved mathematically but NOT physically.
  • #265
The responded differently because they understood the question differently. They had to speculate as to what you meant just like we did, and since they speculated differently, they arrived at different answers.
  • #266
Thank you for your comment regarding my choice of words, "eventually". You and others were correct on wondering what I was referring to when I chose to use the word "eventually" when asking the question what happens eventually when you keep cutting a distance between two objects in half over and over again. I assumed my word vocabulary was better than that. The word eventually does not mean to infinity. Rather it is a undetermined amount of time. Oops! Sorry about that.
I've been out of town for four weeks searching for meteorites but ended up finding historic World War II 50 caliber and 20 mm bullets and shells on the desert in Arizona. I would've responded sooner to your post. Thanks and no reply necessary.
  • #267
This reminds me of this puzzle: An attractive woman is waiting for a male mathematician who is 10 meters away. As each minute passes, the man moves half the remaining distance closer.
Question: Will the man reach the location woman in any finite time?
Answer: No, but he will get close enough for all practical purposes.
  • #268
An infinite number of mathematicians walk into a bar; the first orders a glass of beer, the second orders half a glass of beer, the third orders a fourth of a glass of beer...
The bartender says "You're all idiots!" and pours two glasses of beer.
  • #269
:smile:
  • #270
How many Lebesgue measurable subsets of the reals are there?
  • · Replies 53 ·
10K
  • · Replies 131 ·
12K
  • · Replies 23 ·
  • · Replies 20 ·
16K
