How can we solve these two volume-related questions?
  • Context: MHB
  • Thread starter Thread starter annie122
The discussion revolves around two volume-related questions in calculus, specifically focusing on the description of a solid obtained from a given integral and the computation of the volume of a torus defined by inner and outer radii. The scope includes mathematical reasoning and technical explanations related to solids of revolution.
  • Homework-related
  • One participant initially interprets the integral \(\pi \int_{0}^{\pi/2}\cos ^2x \, dx\) as representing the solid obtained by rotating the area between \(y = \sin x\) and \(y = 0\) over the interval \(0 \leq x \leq \frac{\pi}{2}\), but expresses uncertainty about this interpretation being correct.
  • Another participant clarifies that the formula for the disk method of computing the volume of a solid of revolution about the \(x\)-axis is \(V=\pi\int_a^b f^2(x)\,dx\) and prompts the original poster to reconsider how to describe the region being rotated.
  • A later reply suggests that the solid in question is indeed a torus, despite differences in variable names, and recommends a method for computing the volume of the torus by revolving a circle of radius \(\frac{r}{2}\) centered at \(\left(R+\frac{r}{2},0\right)\) about the \(y\)-axis.
Participants express uncertainty regarding the interpretation of the first problem, and while there is a suggestion that the solid is a torus, the discussion does not reach a consensus on the specifics of the first question. The second problem regarding the torus also remains unresolved for some participants.
There are limitations in the clarity of how the integral relates to the solid being described, and the connection between the provided link and the original question is not fully established. Additionally, the method for computing the volume of the torus is suggested but not explicitly detailed.
annie122
#1 describe the solid obtained by
\pi \int_{0}^{\pi/2}\cos ^2xdx
i thought this meant that the area function is
pi \cos ^2xdx and since \cos ^2xdx = 1^2 - \sinx ^2xdx
it's the solid obtained by rotating region between y = sinx and y = 0 for 0 <= x <= pi / 2.
but this was wrong.
how?
#2 compute the volume of a torus which has inner radius R and outer radius R + r.
no idea.
Re: two volume-related questions
but this was wrong.
how?
The formula for the disk method of computing the volume of a solid of revolution about the $x$-axis is:
$$V=\pi\int_a^b f^2(x)\,dx$$
Do you see now how to describe the region being rotated?
no idea.
I would direct you to this thread which should give you an indication of how to proceed:
http://mathhelpboards.com/questions-other-sites-52/roisins-question-yahoo-answers-regarding-volume-torus-7992.html
i think i now get #1but i don't know how your link relates to my question.
is the solid in question in the thread a torus??
Yes, the names of the variables are different, but it is a torus. I just wanted you to see the method used.
To work the second problem using the variables given, I would recommend revolving a circle of radius $\dfrac{r}{2}$ and centered at $\left(R+\dfrac{r}{2},0 \right)$ about the $y$-axis. Do you see how this will create a torus whose inner radius is $R$ and whose outer radius is $R+r$?
  • · Replies 29 ·
