How can you accurately measure the volume change of an empty juice box?
The problem involves measuring the volume change of an empty juice box after removing air from it, using a beaker of water and a scale. Participants are exploring methods to accurately determine this volume change through displacement and weight measurements.
  • Participants discuss using water displacement to measure volume change and question how the scale factors into this measurement. There are suggestions about weighing the juice box submerged in water and recording weight differences before and after air removal.
The discussion is active, with participants exploring different methods and questioning the roles of various forces involved in the measurement process. Some guidance has been offered regarding the use of the scale and the forces acting on the beaker.
Participants are considering the accuracy of measurements and the implications of water displacement, as well as the forces acting on the system, which may affect their approach to the problem.
charles bigby
Mod note: Misplaced homework moved from General Physics, hence formatting template not shown
Beginner here: Was recently given a homework problem:
You have a scale (any kind), 2L beeker of water, a series of calibration weights, and one empty juice box. You want to accurately measure the volume change of the empty juice box if you suck most of the remaining air out of it.
I kept thinking you want to just measure the difference in volume of the beeker with the box fully submerged, but how would the scale come into things?
How do you measure the difference in volume (as a number that you can write down) with just the beaker?
well i guess that would not be accurate.
If you just guess the amount of water displaced, it will be very inaccurate. How can you measure it?
my friend is saying to fill the beaker with water and to put it on the scale, and zero the scale.Then you put a rod in the punch top of the juice box, and hold the box so that it is just submerged under the water, then to record the weight on the scale. Then he is saying to take the juice box with less air inside, and to do the same thing and record the weight, and the difference is the volume change. How would this work? The amount of water isn't changing, only the volume it occupies.
If you fill the beaker completely, water will go out if you push something into the beaker.
Holding the thing in while weighting, without filling the beaker completely works as well, but it is a bit harder to understand. Think about the force balance on the beaker (there are three forces acting on it).
Would the three force be gravity, the normal force, and air pressure?
You could consider air pressure but that wouldn't help much.
What do you mean by "the normal force"?
Gravity is one, correct.
the normal force of the scale on the beaker, and the force of water in the beaker.
What is "the force of water"?
- Gravity
- Force from the scale
- Think about the person holding the empty juice box into the water. What are the forces involved?
The person holding the juice box is adding the force needed to submerge the box in the water? And this contributes to the total balance on the scale?
19K
  • · Replies 152 ·
12K
