How Can You Analyze and Solve These Complex Differential Equations?
  • Topic:
  • Thread starter DrWahoo
    General
DrWahoo
1) Reduce the quadratic system to its normal form;
$x'=y+x^2 +y^2$
$y'=xy$
2) Consider the following vector field on $R^2$
$x'=\mu x -y-x(x^2 +y^2)$
$y'=x+\mu y -y(x^2 +y^2) $
where $\mu\in\Bbb{R}$. Define the cross section $\Sigma$ to the vector field by
$\Sigma=\{(r, \theta) \in \Bbb{R}$x$ [0, 2\pi]\}$ given $r >0, \theta =0$
3)
Consider the planar system
$x'=x-y-x^5$
$y'=x+y-y^5$
a) Show that $(0,0)$ is the only equilibrium point and study its stability.
b) Use the Poincare-Bendixson Thm to show there exists a periodic orbit to the above system in certain annular region, determine the inner and outer radius of this annular region as accurate as possible.
These are problems my 600 level modeling students were given;
I will give some hints and a complete proof and overview of problem two. Hopefully someone else can chime in and voice their ideas as I love seeing analytical thinking.
On the 2nd problem we are asked;
$\Sigma=\{(r, \theta) \in \Bbb{R}$x$ [0, 2\pi]\}$ given $r >0, \theta =0$We simply put the system into polar coordinates. The usual definitions work in our case, no need for spherical:
So we use
$x=r\cos\left({\theta}\right)$, $y=r\sin\left({\theta}\right)$, $\theta =\arctan\left({\frac{y}{x}}\right)$ ie; $r^2 = x^2 +y^2$
I will leave it to the reader to verify that in our system:
$r'=r(\mu -r^2)$
$\theta'=1$
This implies that the system has a periodic orbit given by $r=\sqrt{\mu}$.
Now we can construct the Poincare Map near this orbit. We then determine the flow of the given system.
By the flow of the system we have ${\varPhi}_{t} (r_{0}, {\theta}_{0})=([(\frac{1}{\mu} + (\frac{1}{(r^2)_{0}}-\frac{1}{\mu})e^{-2 \mu t}]^{\frac{-1}{2}}, t+ \theta_{0})$
Thus we can define the Poincare section denoted, "$\Sigma$" as;
$\sigma ={(r, \theta ) \in \Bbb{R} \times S' | r>0, \theta = \theta_{0}}$
$\implies$ we have a fixed point at the origin $(0,0)$ where $r=0$. Is this orbit periodic? Yes, $t=2*\pi$ returns the orbit, usually denoted with $\omega$ or $\alpha$ to denote which type of limit set. (Check for yourself)
We note that all periodic orbits correspond to a fixed point by def. Thus using $\sqrt{\mu}$, we check the periodic orbits corresponding to this fixed point;
That is $P(\sqrt{\mu})=(\frac{1}{\mu}+(\frac{1}{\mu}-\frac{1}{\mu})e^{-4 \pi \mu})^{\frac{-1}{2}}$.
Then finding the corresponding eigenvalue around the fixed point;
$r=\sqrt{\mu}$ which is $\lambda = e^{-4 \pi \mu} < 1 $
So what does this tell us about the system and in particular about our Poincare map, especially at $(0,0)$.
I will include the graph with some periodic orbits around the origin to show;
if $\mu < 0 \implies (0,0) =$ Spiral sink
if $\mu > 0 \implies (0,0) =$ Spiral Source
Can you guess which phase portrait corresponded to the hypothesis above?
  • Phase portrait of a planar vector field with many blue trajectories spiralling into a common point at the origin, with dashed orange and magenta curves; axes labelled x from -3 to 4 and y from -4 to 3, with the two system equations printed above.
Hint for #3.
Convert to polar coordinates. Set the RHS of each DE to 0 and solve. What possible equilibrium points do we have?
Can you follow the steps from #2 to get the answer?
Another method is to think of solutions to a similar DE, instead of to the 5th power, what if the largest power was 3. Would our phase portraits look any different? How would this affect a general solution to the model if there is one?
