How can you measure compressive strength?
6 replies · 9K views · last reply
LatexZone
It's a really tricky one to work out, but does anyone have any suggestions of how to measure compressive strength?
Thanks a lot.
Compressive strength of a material is measured experimentally. The apparatus plots a stress-strain curve and when the material crushes, the value of the stress is called the limit compressive strength. I'm not really sure what you are asking.
How can you measure compressive strength, that's what I'm asking xD
Not sure how else to put it :'(
One of them would be a vice grip maybe. Any others?
Well it rather depends upon the material.
You can measure it directly by crushing a specimen in a in a calibrated press as Radou has described, or you can measure indirectly by testing a suitably shaped bending specimen to destruction.
ASTM (American Society Testing Materials) has standards on how to test different materials. You can purchase the standards from their website. Basically you have a load cell attached to a motorized piston that simultaneously measures the force and compressive distance on a sample to failure. The samples must be a uniform size and composition.
This might be a DIY approach. The difficult thing to measure is how far the specimen compresses before failure. Get a screw clamp and determine how far the screw end travels with every let's say 1/2 turn. You will still need a load cell to measure force but you should be able to equate force with displacement if the sample is not to brittle. It is worth a try.
