How cavendish determined the value of G
  • Context: Undergrad
  • Thread starter Thread starter Cyrus
    Value
The discussion centers on how Henry Cavendish determined the gravitational constant G through his experiments. Participants explore the methods used by Cavendish, the apparatus involved, and the implications of his findings, including the relationship between gravitational force and the density of the Earth. The conversation includes technical details and historical context, as well as some misconceptions about the equipment used.
  • Historical
  • Some participants express confusion about how G can be determined given the unknowns in the equation G M m / r^2, questioning the role of gravitational acceleration g in Cavendish's setup.
  • One participant suggests that the system is in equilibrium, where the torque exerted by the masses is balanced by the torque from the wire, allowing for the calculation of force and G.
  • There are conflicting claims about the use of lasers in Cavendish's experiment, with some asserting he used a laser while others clarify that he did not have access to lasers and likely used a collimated light beam.
  • Another participant recounts a historical perspective, stating that Cavendish inherited the experimental setup from another scientist and had to reconstruct it, emphasizing that he was not the original inventor of the experiment.
  • One participant mentions an error in Cavendish's original paper regarding the density of the Earth, indicating that he misreported a decimal place, though the exact numbers are not specified.
Participants do not reach a consensus on the specifics of Cavendish's methods or the historical context of his experiments. Multiple competing views are presented regarding the equipment used and the nature of his discoveries.
There are unresolved assumptions regarding the interpretation of Cavendish's experimental setup and the calculations involved in determining G. The discussion reflects varying degrees of understanding about the historical and technical aspects of the experiment.
Cyrus
Hi, I was wondering if anyone could explain how cavendish determined the value of G. I have read that he used a mirror on a small wire to determine the angle and from there determined the value of G. I do not see how you can detemrine G, since there are many unknowns. You have
G M m / r^2.
You know the two masses and their distance, but that is not enough to know G. A few books have said you also know w=mg = G m m/r^2, but this is not true, a cavendish does not factor in g, since the balls move side ways indepent of gravity g. Also, how come in this cavendish the two balls don't come together and touch and just sit there? Thanks, ( I hope Bobg replies :-p )
You are right, distance and masses are not sufficient. From what I understand, the system is in equilibrium. This means the torque exerted by the masses is equal and opposite to the one exerted by the wire (the wire acts like a torsion spring, so by knowing the angle you know the torque). From there you can easily calculate the force and factor G from the gravitation law.
As I said, that's because the wire exerts a torque in the opposite direction, so your your system just 'stops' when the two are equal.
Someone correct me if I'm wrong or unclear :smile:
Cadendish used a laser to bounce off a mirror on the balls and see the angle that the light beam creates after the balls attract each other. I don't know how he exactly used this to calculate it, I've heard that Cavendish calculated G by accident, that he was origionally trying to calculate the density of the earth.
Cavendish didn't have lasers to work with.
So, what did he use to bounce off the mirror?
Probably a collimated light beam but he most certainly did not use a laser!
Schawlow and Townes first proposed the laser in their 1958 publication of their paper detailing the theory and the first working laser was created some years later - long after Cavendish did his experiments.
With regard to the original question, Cavendish measured the torque on a torsion bar supported by a wire. The bar had masses at its ends and those masses were pulled by two other masses to produce the torque. The torque (produced by the gravitational pull of the masses) is proportional to the deflection angle and, by measuring that angle, Cavendish was able to determine the force.
I actually solved this on my own. But cavendish, to my knowledge did not discover this by accident. As it was not even he who invented the experiment. (mitchell?) or some other guy actually invented the experiment. He was a geologist. But he died before he ever got it to work. Cavendish inherited this contraption, and the rest of the junk from this guys lab upon his death. Cavendish actually had to remake almost all of it as the wood had rotted and broken apart. When he did get it finally working he called it weighing the world. (or was it weighing the earth). He did not have a laser, but a focused beam of light which he measured outside the room using a teloscope. (as not to create air currents. ) He found the value of G. and from there he backed out the specific density of the Earth relative to water i think, which he found to be like 5.5 or so. He actually made an error on his original paper. As he put a number in the decimals place as .34 instead of .034. Those arent the actual numbers i just made something up off the top of my head to give you an idea. So his value of the Earth was actually off, something ilke 5.3 instead of 5.5. But to my knowledge, he did know he was calculating G and did not stumble on it. As he needed g in order to find the mass of the earth.
  • · Replies 24 ·
