How come I can't use m(v^2/r)=kx for this problem?
  • Thread starter Thread starter kabailey
The discussion centers around the application of the formula m(v^2/r) = kx in a problem involving a block attached to a spring. The block is kicked with an initial horizontal velocity, causing it to stretch the spring as it moves. The problem was solved using kinetic energy and angular momentum conservation, leading to the conclusion that m(v^2/r) is only applicable in uniform circular motion. Since the block's path is not circular due to the spring stretching, this formula cannot be used. The clarification emphasizes that the stretching of the spring indicates a non-circular trajectory.
kabailey
Relaxed spring is sitting on a horizontal surface. A block is attached at one of its ends is kicked with a horizontal velocity, v1, given to it. The block will move and stretch. Find the distance, x, the spring will stretch. X is in meters.
Energy 1/2 mv1^2 = 1/2 mv2^2 + 1/2 k x^2
Angular momentum mv1l0 = mv2(l0+x)
The problem was solved using kinetic energy and conservation of angular momentum formulas.
My question is, why doesn't m(v^2/r)=kx apply for this problem? Is it because m(v^2/r) is to only be used in uniform circular motion and the object in the problem moves in the shape of an ellipse?
I have no idea what path this thing moves on, but if the string stretches, then it can't be a circle.
understood, but does m(v^2/r) only apply to a circle?
Yes.
Steely Dan said:
Yes.
thank you!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
