How could i dissolve iron powder
The discussion revolves around methods to dissolve iron powder to create a standard iron solution at a concentration of 1 g/L. Participants explore various chemical approaches, safety concerns, and the nature of the iron powder being used.
  • Experimental/applied
  • Some participants suggest using 6 N HCl as a common method for dissolving iron residue.
  • Others propose using diluted HNO3, noting that it dissolves iron quickly but caution against passivation effects if not properly diluted.
  • Concerns are raised about potential side reactions when using nitric acid, including the formation of ammonium nitrate and the risk of explosive reactions.
  • One participant mentions that the nature of the iron powder may affect its solubility, suggesting it could be a hydroxide precipitate.
  • Electrochemical methods are mentioned as an alternative way to dissolve iron into solution.
  • A side discussion arises regarding the difference between "solvating" and "dissolving," with participants clarifying the concepts and their implications in the context of solubility.
Participants express multiple competing views on the best method to dissolve iron powder, and there is no consensus on a single approach. Safety concerns regarding the use of nitric acid are also debated, with differing opinions on the risks involved.
Participants note the importance of understanding the specific form of iron powder being used, as this may influence the dissolution process. There are also mentions of safety protocols and past incidents related to the use of nitric acid.
This discussion may be useful for chemists, laboratory technicians, and students interested in methods for preparing iron solutions and understanding the chemical properties and safety considerations of iron compounds.
seragrefaat
I want to make a standard iron solution 1 g/L by using iron powder and i can't dissolve it by any way. Is anyone have an idea? thanks in advance.
Chemistry news on Phys.org
What form of iron are you after? Iron(0), iron(II) or iron(III).
6 N HCl solution. Use it all the time to clean up flasks with iron residue.
HNO3 dissolves iron quickly, but it doesn't have to be concentrated, you have to dilute it with some water (6N should be ok) or the reaction will be blocked by passivation. Be careful to red smokes of NOx, do it in a hood.
Be careful with the nitric acid. I'm wondering if ammonium nitrate is a possible side product if you try to dissolve Fe with nitric acid. One chemist we had was trying to clean out his glassware of iron residue with nitric acid and caused a massive explosion. Luckily he wasn't hurt, but glass shards went flying everywhere. There were huge 7+ inch shards of glass embedded 8 inches in the wall.
With an excess of iron it should be possible; it is, with excess zinc and HNO3. However, if NH4NO3 do really reacts in that way with HNO3, it should be, at least, dry.
It's quite difficult for me to believe it was only Fe, NH4NO3 and HNO3, are you sure there wasn't something else, even in small amounts, in it?
lightarrow said:
With an excess of iron it should be possible; it is, with excess zinc and HNO3. However, if NH4NO3 do really reacts in that way with HNO3, it should be, at least, dry. It's quite difficult for me to believe it was only Fe, NH4NO3 and HNO3, are you sure there wasn't something else, even in small amounts, in it?
We don't know. There could have been some organic material in there as well. ANyway, we aren't allowed to use nitric acid to clean glassware anymore.
Not trying to hijack your thread I just had a real quick question that isn't worthy or starting a new thread.
Whats the difference between "solvating" and "dissolving"? I read that solvation is also called dissolution. Is dissolution just the process of dissolving? If I add salt to water I would be dissolving the salt in the water. Would I also be solvating the salt in the water or would I be solvating the water with salt?
They are completely different cocepts.
"Dissolve" means to bring something in solution, "solvate" means to make the molecules of that compound surrounded by water molecules, bound with some kind of weak bond, as ion-dipole, dipole-dipole bonds.
If you dissolve NaCl in water you will also have solvation of Na+ and Cl- ions, that is every ion in water will react with H2O molecules forming a weak bond with them (with a variable number of water molecules, depending on the kind of ion, concentration, temperature, ecc.).
In general you will always have more or less solvation, even if in some cases it could be so weak that you can neglete it; in that case you could have dissolution but with very little solvation; dissolution is a more complex phenomenon, that includes also solvation, in general (but not necessarily) but also other processes, that is the brokening of the salt's crystal, for example, and the increasing of the entropy due to the mixing solute/solvent.
So, even if "solvation" do certainly affect solubility, it's different from "dissolution".
it is a standard solution i think Iron(0) is correct
ok i'll try and see
6N HNO3? i didn't try to use it, thanks for the advice.
thanks for the advice, and how is your friend now?
it is ok my friend we all learn
thanks for the information
At the end and to be more clear i'll use this standard solution - after dissolving - to make a calibration curve for iron spectroscopic determination, now i'll try to use 6N HCL and 6N HNO3 separately of course and see.
I'm curious to know exactly what is the iron powder that you're employing; how was it obtained? It could be one of the many forms of the hydroxide precipitate. One other way to dissolve iron into the solution is through electrochemistry methods.
The iron powder i talk about is the one found in this link
http://www.sigmaaldrich.com/catalog/search/SearchResultsPage/PricingAvailability/RIEDEL;12312 1 Kg pack
The link is not functional.
If you are interested in dissolving zero valent iron, you should use iron pentacarbonyl. Sigma Aldrich product number 481718-25ML(100ML). Be careful, it's very toxic.
i would go for simply, 5 ml. of dilute sulfuric acid then heating.. or mix of HNO3 & HCL then heating.. the last one should certainly dissolve it.
Why the need to add HCl? HNO3 alone (not concentrated or Fe would be passivated) dissolves it well.
hm. Not to change topic (I don't feel like starting a thread for small inquires) but isn't iron powder used in some military hand grenade. I do not remember, but I think it is used in either stun grenades or maybe in some napalm type grenade used in Vietnam. Yeah, cause when it reacts with "something" rust, it let's off heat strong enough to penetrate metal and can burn for hours.
No, I've heard of that too.
23K
