How Can We Observe Black Holes Growing?
  • Context: High School
  • Thread starter Thread starter mef
    Black holes Holes
This discussion centers on the misconceptions surrounding black holes and the perception of time for observers at various distances. It is established that while distant observers perceive infalling matter as taking an infinite amount of time to reach a black hole's event horizon, this is a misunderstanding. In reality, matter can cross the horizon in finite time according to its own clock, particularly when it has zero angular momentum. The Schwarzschild coordinates are crucial for understanding these dynamics, but they do not provide a universal time applicable to all observers.
  • Understanding of general relativity (GR) principles
  • Familiarity with Schwarzschild coordinates
  • Knowledge of black hole event horizons
  • Concept of angular momentum in astrophysics
  • Study the implications of Schwarzschild geometry on black hole dynamics
  • Explore the concept of proper time in general relativity
  • Investigate the role of accretion disks in black hole growth
  • Read about the mathematical frameworks used to describe black hole event horizons
Astronomers, physicists, and students of general relativity who seek to clarify misconceptions about black holes and their interaction with surrounding matter.
  • #61
Orodruin said:
Careful with your statements. There is no ”when” an object passes the horizon for a distant observer as that would require an unphysical simultaneity convention.
Hmm, convention yes. Unphysical is a matter of taste. I would call simultaneity defined from a family of free falling observers in a manner equivalent to how standard cosmological simultaneity is defined, a physically plausible convention. There is no reason a stationary observer is not allowed to adopt it, and then be able to state, per this convention, exactly when some body crosses the horizon.
  • #62
That does not make it physical. It is also not necessary to compute the time on the infalling observer’s clock as it passes the horizon. Furthermore, the Schwarzschild t coordinate is arguably more ”physically plausible” and gives a different answer.
  • #63
Point remains there is no objective definition of physically plausible. It is a matter of aesthetics. To me, there are many physically plausible conventions possible. And if you want to talk about horizon crossing events in relation to an external stationary observer, you pick one that reaches the horizon.
  • #64
But this is precisely the point. You can obtain any answer you want just by choosing coordinates. This makes the "what is the time for the external observer when the object crosses the horizon" an unphysical one. Sure, you can compute it based on some simultaneity convention, but really, why bother? The same thing goes for cosmology. You can compute the distance to an object "now" (according to standard cosmological choice of FLRW coordinates) but that really holds very little physical significance and it cannot be measured anyway.
  • #65
Of course, there is the invariant transition, for any external observer, of when no part of dropped probe's history is in its causal future anymore. That is, the time after which any light signal sent by the external observer will reach the singularity after the probe has already reached it.
For an 8 solar mass BH, and an external observer hovering at twice the SC radius, this transition is just 242 microseconds after dropping a probe. Any time after this (but not before) it is possible to consider that the probe has reached the singularity.
  • #66
That is a good criterion. Of course, it cannot be measured, just predicted. But with knowledge of the maximum thrust of the vehicle, you could place an upper bound on it.
  • #67
I find I still rebel against the notion that "not invariant" must mean "not physical". IMO, length contraction and time dilation are frame variant physical phenomena.
In the current context, consider yet another example of IMO physically plausible, coordinate dependent ways to state that an object has crossed the horizon at some time for a distant observer:
In GR, while there are no global inertial frames, there are local inertial frames. Then one can extent these to large scale coordinates by geodesically extending the basis (the result is Riemann Normal coordinates defined by a 4-velocity at an event). Then it is true that for such a coordinate system build from a momentarily stationary observers, such an extended coordinate system (though different from standard Schwarzschild coordinates) will never include a horizon crossing event. However, for an observer a light year from a stellar BH, a year after it formed, such coordinates built for an observer moving just 1 meter/second toward the BH, the horizon and singularity will included in the present. Thus, claims that the horizon never forms for distant observers are patently false, unless you somehow want to exclude any observer not completely 'stationary'.
  • #68
I have to disagree with this. I would say that "length contraction" and "time dilation", if they are to be considered physical phenomena, can and must be defined as invariants. An observer in a particular state of motion can measure invariants that can be appropriately described as the "length contracted length" of an object moving relative to that observer, or the "time dilated clock rate" of a clock moving relative to that observer. Those invariants are unproblematically physical things, and, with proper definition, will in fact correspond to what are usually called the "frame variant" quantities "length contraction" and "time dilation". And with a scenario properly set up along such lines, one can usefully discuss "length contraction" and "time dilation" in terms of invariants.
However, many discussions do not properly put into place or consider the background that needs to be set up to define such concepts in terms of invariants (and many participants in such discussions have no idea either that such a background can be put in place or that it needs to be). And not all coordinate-dependent quantities can even be given a useful correspondence with an invariant.
  • #69
I assume you are allowing the metric in terms of such "extended" coordinates to vary from the Minkowski metric? Otherwise this construction will not work as soon as tidal gravity effects become non-negligible.
Also, even allowing the metric to vary, such a coordinate patch can only be extended through a region in which none of the geodesics being used cross. Perhaps this is what you have in mind when you say that no such coordinate patch constructed from the 4-velocity of a static observer will include a horizon crossing event (since radial spacelike geodesics in any such construction would cross at a point on the horizon).
  • #70
These are concepts that I find confuse students for no real reason as they start obsessing over why the rod does not break in frames other than its rest frame from being pushed together or run in loops around the twin paradox. A bit similar to how we tend to not use relativistic mass.
Are they physical? It depends, as long as there is an operational way to measure them that gives the same result regardless of frame they will be, but they are always accompanied by the caveat of ”as measured by X” or something to that effect. We do not ascribe the measurement of some random observer as the length of an object (although we do define rest length as the length measured in the object’s rest frame).
For the horizon crossing, the same is true, you cannot define the time of horizon crossing from picking a random coordinate system. Only a time in that system, which to my understanding does not really solve the OP’s problem - which partially is wanting to use Schwarzschild t as the time coordinate.
There generally is no guarantee that such a construction will actually cover the part of spacetime we are interested in. If they did we would not need to worry about using local coordinates at all. You could even end up in a situation where the simultaneities cross, making it possible for events with timelike separation to be time reveresed in the frame and I don’t know what to call that if not unphysical.
  • #71
Of course the metric is not Minkowski. Riemann Normal coordinates are a coordinate family definable in arbitrary pseudo-Riemannian manifold.
Fermi-normal coordinates are the ones that often have limited coverage due to geodesic crossing, because one requires spacelike geodesics 4-orthogonal to different events along a world line. Riemann Normal coordinates are defined simply by geodesically extending the tetrad at one event, based on a 4-velocity at that one event. Crossing of geodesics does not arise. There are other reasons coverage may not be global, but not due to geodesic crossing. In the case at hand (and even for a Kerr BH), defining such coordinates for a distant event from an old BH with a 4-velocity slowly moving inward relative to a KVF tangent will include the horizon and singularity in the 'present'.
  • #72
You are mixing up Riemann-Normal coordinates with Fermi-Normal coordinates. The problem you describe occurs for the latter. In the case at hand, it occurs for Fermi-Normal coordinates based in a stationary observer precisely because their world line is not inertial.
  • #73
This is false. The simplest counter example would be the sphere where all geodesics from a point cross at the opposite point. However, you can also find examples in Schwarzschild spacetime. Take an observer in a circular orbit and an observer in radial outward motion. There will exist a radial geodesic motion exactly such that the observers will meet twice. Once when the radially moving observer is moving away from the black hole and once when moving towards it. Both of these events clearly lie on two geodesics that therefore do cross more than once.
  • #74
But those are intersections of two timelike geodesics with different 4-velocities. They wouldn't both be part of the same Riemann-Normal coordinate system. I concede (and stated) there may be limitations on the valid coverage of Riemann-Normal coodinate patch, but not in the case at hand - towards a BH for slowly inwardly moving (relative to KVF) defining 4-velocity.
  • #75
Of course they would. The coordinates would be the components of the 4-velocities.
  • #76
How? You pick one timelike vector and 3 spacelike vectors, all mutually orthogonal. Each specifies a unique geodesic. Your example is two timelike geodesics intersecting twice. Exotic cases like spacetimes with CTC, or closed spacetimes, can have intersections, but then you still get as much coverage as can be expected. (Even in most spacetimes allowing CTC, they are not geodesics).
  • #77
No, that would just give you the coordinate axes, but that is not enough to specify a coordinate system. Riemann normal coordinates are based on a map from a subset of the tangent space of one point to the manifold itself, not just four vectors. The four vectors you mention are the basis vectors used for the tangent space and the Riemann normal coordinates defined by a tangent vector are its components in this basis.
  • #78
Agreed, but that still doesn't explain how the two timelike geodesics you described would be relevant to one Riemann-Normal coordinate system. Each would be part of the definition of a different Riemann-Normal coordinate system.
  • #79
No. Any tangent vector forms part of the Riemann normal coordinate system (at least until you start dealing with double coverage of points). This is precisely the point of the Riemann normal coordinates. You define the geodesic map from the tangent space of a point p to the manifold itself. Then you introduce coordinates on the tangent space by picking four orthonormal basis vectors of the tangent space. The coordinates of a point in the manifold are then the components in that basis of the tangent vector that maps to that point. This tangent vector is not necessarily (and in most cases not) one of the basis vectors.
The problems with Riemann normal coordinates not being global arise precisely because geodesics do cross.
  • #80
To take the sphere as an example: You start at one point ##p## and define the geodesic map ##v\to \exp(v)## from ##T_p \mathbb S^2## to ##\mathbb S^2##. The geodesics are the great circles and we can normalise the map such that the antipodal point is reached when ##|v| = \pi R##. Taking two unit vectors ##X## and ##Y## in ##T_p \mathbb S^2## defines a map from ##T_p \mathbb S^2## to ##\mathbb R^2## through the projection ##v \to (x,y) = (g(v,X),g(v,Y))##, which is basically taking the components of ##v## in terms of ##X## and ##Y##.
The map from ##T_p \mathbb S^2## to ##\mathbb R^2## is a bijection and so invertible. To define a point on the sphere you need to specify coordinates ##x## and ##y##, corresponding to ##v = xX + yY##, which generally is not equal to neither ##X## or ##Y##. The point on the sphere to which ##v## maps still needs to be defined by following the geodesic defined by ##v##. Where this fails to be a global coordinate system is when all of the tangent vectors of length ##\pi R## map to the same point because the geodesics cross. Even if it is the case on the sphere, it is not necessary for the coordinate axes to cross for the coordinate system to fail at a point where geodesics cross. In the construction above, ##v_1 = \pi R(X+Y)/\sqrt 2## and ##v_2 = \pi R X## correspond to coordinates ##(\pi R/\sqrt 2, \pi R/\sqrt 2)## and ##(\pi R, 0)##, respectively. Even if the geodesic of ##Y## did not cross those of ##X##, this would be a problem for the coordinate system as two different sets of coordinates map to the same point. It is therefore sufficient that any two geodesics from an event cross at a different event for Riemann normal coordinates to be non-global.
The reverse is however not true. If none of the geodesics cross, then the map from the tangent space to the manifold is invertible. This can still fail to be a global coordinate system (if the map is a injective but not surjective), but geodesics crossing is one of the ways that a coordinate system can fail being global (by being surjective but not injective).
  • #81
Sorry maybe I didn’t get your point: ##v_1## and ##v_2## given as linear combination of unit vectors ##X## and ##Y## are defined such that ##|v_1| =|v_2|= \pi R##. So on the sphere the 'normalized' geodesic map ##v\to \exp(v)## from ##T_p \mathbb S^2## to ##\mathbb S^2## map both to the the same antipodal point w.r.t. point ##p##.
Was it just an example on the sphere of two non-coordinate axis that happen to intersect at a common point though ?
  • #82
It is an example of how the mapping of a vector that is not one of the vectors defining the coordinate system is still highly relevant for what part of the manifold the coordinates cover.
  • #83
Ah ok, so you're basically saying not just the mapping of coordinate vectors ##\pi R X## and ##\pi R Y## may intersect at a common point, actually the same 'issue' extends for the 'exponential mapping' of other vectors elements of ##T_p \mathbb S^2##.
  • #84
Ok, I see my mistake. I was inventing yet another coordinate system as follows:
Construct Riemann Normal coordinates for the SC r-t plane, then cross with S2. The spherical symmetry was “ingrained” in my head, so I didn’t see how I was violating the definition of RN coordinates.
However, my proposed coordinates do have the properties I claimed - they are a global, “natural” extension of a local frame in the case of SC geometry.
Thanks for clarifying the details of RN coordinates.
  • #85
By the way: is this 'problem' someway related to the 'geodesically complete' property of the manifold endowed with an affine connection ?
  • #86
No. The issue raised by @Orodruin would occur, for example, in the spherically symmetric solution for a fluid ball surrounded by vacuum.
  • #87
Well, my issue still remains that - however natural - it remains a distinct artefact of the coordinates. While you may or may not be able to construct an invariant operational way of measuring this, the statement itself of ”when” horizon crossing occurs remains a coordinate dependent statement.
  • #88
Ah ok, the geodesically incompleteness might be in cases like the punctured plane for instance.
  • #89
What I want to push back against is that there is any natural sense in which “horizon crossing never occurs per an external observer”, something we get over and over - even some physicists make this absurd claim. Providing physically motivated alternatives to SC time coordinate is one way to do this. And your claim that these are unphysical is both unhelpful and judgmental.
  • #90
In Schwarzschild spacetime, the horizon crossing is, by definition, spatially separated or in the causal future of any external observer. This is the invariant physical reality. As I have also made clear, this in no way means that the infalling object freezes on the horizon. The statement that horizon crossing never occurs for an external observer is wrong, not because there is an arbitrariness in how to define your coordinates, but because the arbitrariness itself makes the question ambiguous. I believe that it is the insistence on ascribing physicality to particular coordinates that is unhelpful and biased and the source of many misunderstandings of relativity - both special and general. Relativity ultimately is a theory about spacetime geometry where relevant physical question are invariant (although they may have particular interpretations in particular frames).
  • · Replies 43 ·
  • · Replies 31 ·
  • · Replies 67 ·
  • · Replies 23 ·
  • · Replies 22 ·
  • · Replies 40 ·
  • · Replies 22 ·
  • · Replies 20 ·
