How Do Brightness and Luminosity Differ in Energy Terms?
  • Thread starter Thread starter sancharsharma
    Luminosity
Brightness and luminosity differ fundamentally in how they measure light; brightness is a photometric quantity related to human perception, while luminosity, measured in candelas, is a radiometric unit that accounts for the direction of emitted power. A watt measures energy transfer but does not directly indicate brightness, as different bulb types can emit varying brightness levels despite similar wattages. Radiance, a key concept in this discussion, describes how much power is emitted in a specific direction and is conserved in non-absorptive optical systems. The conversion between radiometric and photometric units is complex due to the human eye's varying sensitivity to different wavelengths, necessitating the use of a standard luminosity function. The candela is considered a fundamental unit because it encapsulates the directional aspect of light emission, despite being derivable from power and angles.
sancharsharma
I cannot get a feel of what is luminosity physically...
Can anyone explain me the difference between energy transfer in terms of brightness (which is measured in Watts) and luminosity (which requires a new definition of units, candela)??
Try not to be confused when dealing with Watts.
It's easy to think that a 100 watt light bulb is brighter than a 60 watt bulb, but it's only true for bulbs of the same type. A 25 watt bulb of a different type can match or even exceed the brightness of the original 100 watt bulb.
A "watt" is a relationship of voltage and current. It should not be considered a measure of brightness.
Radiometry has (possibly) the most horrid system of units in all of science, except for Photometry. "Brightness" is a photometric quantity (how your vision responds) related to the radiometric quantity 'radiance'. Radiance has units of W/sr*m^2 and is the most basic way to describe a source: how much power is emitted (W/m^2) and in what direction that radiation propagates. Radiance is conserved for all optical systems that do not have absorption present.
The fundamental relationship for radiative energy transport takes into account not only the amount of radiated power, but also the relative orientations of the two surfaces (which is why there's steradians floating around)
A candela (Cd) is a radiometric unit of "radiant intensity" has units of W/sr: in what direction the radiated power propagates. "Radiant flux" is a radiometric quantity with units of W: how much energy flows through a surface per unit time.
Edit: photometric units, like brightness and luminance, take into account the fact that your eye does not respond to all wavelengths the same- you are much more sensitive to green than far-red (or far-blue). There's a 'standard curve', the luminosity function, that allows you to convert from radiometric to photometric units, but it's far more difficult to convert a photometric unit to a radiometric unit.
Hope this helps...
thankyou... but I am still not able to grasp that why is candela a fundamental unit if it can be derived from power and angles. explain please...
Thread ''splain this hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
