How do I calculate conductor cross-sectional area for resistance?
  • Thread starter Thread starter suppo
    Area
10 replies · 5K views
suppo
Im a first year electrical apprentice and I can't work out the area for resistance. The formula is R = PL/A :eg 20mm by 9mm conductor the answer has to be in meters squared can you show me the formula please?
Are you just asking how to find out how many meters-squared an area 20 mm by 9 mm is?
If so, just convert each length into meters (0.020 m x 0.009 m) and multiply them.
- Warren
A question I have for homework is find the resistance of a 500 meter length of copper conductor having a cross sectional area of 20mm by 9mm? I know the resistivity of copper is 1.72 x10-8 and L is given 500, the A I think is 1.8x10-4. So R=PL/A !.72x10-8 x 500 / 1.8x10-4. The answer I get is 4.7 but the answer I'm supposed to get is 0.133 . Can you tell mr where I've gone wrong?
I get 0.0477 ohms (this number is also within 10% of a number generated from the american wire gauge tables, so I believe it is correct).
Are you sure you have written down the dimensions correctly ?
The actual question is. A copper conductor is 200 meters long and has a rectangular cross section of 12mm by 8mm. It's resistance is 0.01 ohm. Find the resistance of 500 meters of a copper conductor having a cross section of 20mm by 9mm?
That's something else.
[tex]R=\rho\frac{l}{S}[/tex]
Use this for the first conductor to find [itex]\rho[/itex] and then use this resistivity to find the resistance of the 2-nd conductor.
Daniel.
I did try that Daniel but I still can't arrive at the answer the course notes gives . I think my calculations for area isn't right. Is 20mm by 9mm 20+9=29 x 10-3squared =2.9x10-5 or is it 20x9=180x10-3squared 1.8x10-4. Or is there another way?
