How do I calculate Heisenburg's Uncertainty Principle?
The discussion revolves around the Heisenberg Uncertainty Principle, specifically focusing on calculating the minimum uncertainty in momentum given a specified uncertainty in position for an electron. The original poster attempts to apply the principle using constants and conversions from picometers to meters.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the calculations involving the uncertainty in position and momentum, questioning the conversion of units and the use of significant figures. There are attempts to clarify the correct interpretation of the uncertainty principle and the constants involved.
The conversation is ongoing, with participants providing feedback on the calculations and raising concerns about significant figures and unit conversions. Some suggest that the original poster may be misinterpreting the requirements for significant figures in their answer.
There is mention of the problem being graded and the original poster's concern about the implications of their calculations. The discussion also touches on the acceptable range of answers for the online homework system.
Ng Yau Ming
The uncertainty in the position of an electron along an x axis is given as 28 pm. What is the least uncertainty in any simultaneous measurement of the momentum component px of this electron?
(Uncertainty in x)*(Uncertainty in momentum in x) >= hbar/2
hbar=h/(2*pi)
I know Heisenberg's Uncertainty Principle states that there has to be a minimum amount of uncertainty. Where the minimum uncertainty is hbar/2.
My attempt at the solution
Uncertainty in x = 28E-12 m (Turn pm into m)
h=6.63E-34 (constant)
hbar=1.055`19E-34 (constant)
hbar/2 = 5.275986363E-35 (constant)
Since the formula is
and that it is asking for the minimum uncertainty, therefor minimum amount of uncertainty would be when it is hbar/2
(Uncertainty in x)*(Uncertainty in momentum in x) = hbar/2
So to calculate uncertainty in momentum
(Uncertainty in momentum in x)= (hbar/2)/(Uncertainty in x)
The answer I got is 1.884280844E-24
However this is wrong.
The only thing I can think of is that I got my magnitudes wrong? 28 pm should be 28E-12 m correct?
Im terribly sorry. I know this should be a simple question but I cannot figure out what is wrong with my calculations.
Assistance would be much appreciated.
Thank you.
Edit : Disclaimer I know this is on the homework forum but I need to tell you this homework is graded. I am sorry if I should not post this if it has to be graded
Ng Yau Ming said:
Homework Statement: The uncertainty in the position of an electron along an x-axis is given as 28 pm. What is the least uncertainty in any simultaneous measurement of the momentum component px of this electron?
Homework Equations: (Uncertainty in x)*(Uncertainty in momentum in x) >= hbar/2
hbar=h/(2*pi)
Thank you.
Why do you think it is wrong?
Note that you have a lot of (unjustifiable) significant figures in your answer.
I don't quite understand what you mean by unjustifiable. Sorry english isn't my strong language. But Ill try to explain what I think is wrong
Most likely it is the significant figure section.
The answer wants it in Ns, so I changed pm to m. (28 pm to (28E-12 m or 2.8E-11 m))
Used the Js form of h instead of eVs (h = 6.63x10^34 Js)
So they are all in standard units and I am not using the wrong numbers
I tried to check whether i misunderstood pm as picometers, when its supposed to be something else but the only alternative was P for peta (10E15), which I doubt is the case.
I don't think I am misunderstanding it, as it tells us the minimum amount of uncertainty. So taking the lowest possible value, hbar/2 should be the minumum.
Look up significant figures. You only have two in the value for ##\Delta x##. So you are not justified in having more than two in your answer.
The answer to the question has a ±5% to the answer, so even if the answer is 1.9E-24, my answer of 1.8842808E-24 should be accepted. So that rules significant figures out.
So maybe my next mistake is an error when conversion of pm to m?
Or maybe when calculating the Heisenberg Uncertainty principal I should be using the eV version instead of the Js?
You are missing the point. You are stating a meaningless number in that the precision that you have used is totally unjustified. 1.88 would be barely justified. 1.8842808 is just silly.
And by the way, this is NOT just quibbling. If you don't understand it, you should think about it / study it until you do. If you don't understand significant digits, there are some problems where it will cause you grief.
What do you mean by this? Accepted by what? You leave me with no idea why you think your answer is wrong.
You definitely shouldn't be converting to ##eV##.
I'm sorry. Its an online homework that accepts a range of ±5% of the actual value. And usually the actual value given has lots of decimal places. I put lots of decimal places in the answer just so I don't accidently fall out of the range. So any value I type as long as it is within the range will be accepted.
Also I mixed up significant figure for that (x10^n) thing here.
I am terribly sorry for that. What I probably mean is magnitude.
Edit : The question did not specify to use 2 significant figures
Edit 2 : Previously they did also do not mind the amount of significant figures
I get what you get for SI units. Does the question specify the units for the answer?
Yes over here
The answer wants it in Ns or kgm/s
Ng Yau Ming said:
Yes over hereThe answer wants it in Ns or kgm/s
I'd just move on. It's a conceptually simple question in any case.
To add, you can correct the uncertainty in the last name from Heisenberg into the (almost?) 100% certain Heisenberg. It will make the HW seem better ;). Not criticizing, you're not a native English speaker, though you speak English way better than I will likely speak your language.
Understood. I'll have the homework coordinator look at it in a few days and focus on the others for the time being.
Thank you.
Understood.
Thank you
Textbooks occasionally have wrong answers in the back, so I wouldn’t be surprised if online homework systems have them also. ?:)
Your calculations look OK to me (and my calculator), except for the number of significant figures in the final answer. On a written homework or exam, I’d accept only two or three digits, two being the strictly correct number and three to be generous.
Understood. I will keep that in mind during the examination. However in the exercises they will usually give out answers with a lot of digits and I usually put a lot of digits too just to ensure I don't fall out of that 5% range.
Thank you for your advise
1.88 has an error range of +/- 1/2 out of 188, so about .5% (that's 1/10th of 5%). Using more significant digits can't possibly put you outside of the 5% range.
Again, since you don't seem to understand significant digits, I suggest that you study about them until you do.
  • · Replies 20 ·
  • · Replies 32 ·
9K
