How do I calculate the repelling Force of an Electromagnet?
The discussion centers on calculating the repelling force of an electromagnet, specifically targeting a force of 2000 Newtons. The required magnetic field strength is determined to be 400,000 A/m. Key factors influencing this calculation include the shape and dimensions of the magnets involved, as well as the properties of the materials used, such as unmagnetized iron. The energy density and force equations provided are crucial for deriving the necessary current for the electromagnet.
  • Understanding of electromagnetism principles
  • Familiarity with the formula for energy density: Edens = ½*B*H
  • Knowledge of magnetic field strength and its units (A/m)
  • Basic grasp of force calculations in physics
  • Research the relationship between current and magnetic field strength in electromagnets
  • Study the effects of magnet shape and dimensions on magnetic force
  • Learn about the properties of materials like unmagnetized iron in magnetic applications
  • Explore advanced electromagnet design techniques for specific applications
Engineers, physicists, and hobbyists involved in electromagnet design and applications, particularly those needing to calculate forces and current requirements for specific projects.
jason Kenedy
Hello everyone, I am working on a project and I am trying to figure out the formula to use. My goal is to calculate the amount of current needed to create an electromagnet with a strong enough field strength to repel a force of 2000 Newtons.
thank you
The short answer is: 400000 A/m.
But of course it depends on:
* What kind of magnet ( shape ).
* Dimensions of the magnet and the other magnet to be repelled. ( for example unmagnetized iron will always be attracted ).
So you need to fill out "All known data:".
Thanks. Actually I just found this formula. I can reverse solve for m1 and m2 which is the pole strength of each electromagnet I would be using for the project.
and then solve for the current I need.
I don't recognize this formula. What is m1 and m2: Masses, or?
Say you have two magnets kept apart with a distance, s. The cross section areas of the magnets are A. The energy density within the airgap will be
Edens = ½*B*H [ J/m3 ] ( = ½*μ0*B2 )
The energy in the airgap will be E = ½*B*H*Volumeairgap = ½*B*H*s*A
Now, you can find the force: F = dE/ds = ½*B*H*A.
But what is the size of A?
Thread 'Colors in a plasma globe'
I have a common plasma globe with blue streamers and orange pads at both ends. The orange light is emitted by neon and the blue light is presumably emitted by argon and xenon. Why are the streamers blue while the pads at both ends are orange? A plasma globe's electric field is strong near the central electrode, decreasing with distance, so I would not expect the orange color at both ends.
