How do I determine the speed of my adsl internet cnnection?
  • Thread starter Thread starter Hyperspace2
    Internet Speed
To manually assess ADSL connection speed, users can check the LAN sent and received status or download a file to observe the download speed. However, many factors can influence speed, such as attenuation and distance from the Central Office (CO). Testing through independent speed test sites is recommended for accurate results, as manual methods may not provide a complete picture. A user reported a download speed of 0.12 Mb/s and an upload speed of 0.06 Mb/s from a distance of 3 km from the CO, which aligns with expected performance for ADSL connections. It's important to differentiate between megabits and megabytes when reporting speeds. Users can also log into their router's interface to view assigned speeds and settings, which may help in troubleshooting performance issues.
Hyperspace2
I have an adsl conncection . Please don't refer me any web sites that will help me find speed. I want to find it manually. Is that I find by looking LAN sent and received status? Or I download a file and look the download speed .
Computer science news on Phys.org
There can be many things that will affect the download speed, so no, you can't tell that way.
Why don't you want to test your speed by going to a free test site?
i was trying to know if we could do it manually. My ISP company tells it to be 128 kbps.
Not without somewhat specialized and comparatively expensive equipment as opposed to a test site.
Have you tested it on an independent site to see what you get? With ADSL you get a faster download and slower upload. attenuation can cause speeds to decrease, disntnace from the CO will affect it, I've even known a compnay that were nextdoor to the CO, but there was an old load coil between the buildings that made the distance almost 2 miles.
I just tested with speedtest.net . It shows download speed is 0.12 Mb/s whereas upload speed is 0.06 Mb/s . I am about 3km away from my CO.
Evo is correct.
And using speakeasy and some of the test sites use a file operation to test.
I know people who have had lots of problems with the install and the wire quality. You are fairly far at 3kms.
You should also check your own settings. Use opendns and see how that impacts your performance. Is your system fairly clean? How many socket processes are running?
Does the original poster want his ultimate cached speed, true sustained down and upload, or latency speed.
128kbps = 16KBps = 0.015625 MBps = 0.125 mbps
so make sure you're reporting whether its megabits or megabytes per second. It looks about right for your download.
Secondly, most upload speeds are WAY under the download of your connection. I bet if you check your agreement its something like 128kpbs UP 64kbps DOWN
isnt there something in the command prompt along with the ping xxx.xxx.xxx.xxx command? that will do what you want?
I am using Bharti Airtel ADSL broadband services , and I use Beetel Router to connect to the service,
You can view the speed assigned by your ISP to your router,( and generally this is the original speed which your ISP gave to you ),
My router displays a maximum speed " 2500KBps upstream and ~550KBps downstream / sec.".
If this is what you are searching for then, you can login to your router's main page and check these values ,
1.Generally "http://192.168.1.1/main.html" is the default address for your accessing your router from web browser. ( In case this address is different , then you can see your network adapter/LAN status and check out the main/first I.P.,if you are using DHCP allocated I.P. addr.)
2.The default login credentials for most routers are "Admin" and "password" , or "admin" & "admin" .
3.Once you are logged into the router's main page, i.e. /main.html you will be able to see couple of options which is probablly what you are looking for.
4.For taking a fresh speed, reboot your router, using /reboot.cgi
THis works in my case, hope it does for you as well.
Hrishi.
