How do i integrate: square root of((x^2)-4) ?
6 replies · 3K views · last reply
sara_87
how do i integrate: square root of((x^2)-4) i know i have to use substitution but what do i substitute?
Well, I remember that [itex]sin^2(\theta)+ cos^2(\theta)= 1[/itex] and if I divide both sides of that by [/itex]cos^2(\theta)[/itex], I get [itex]tan^2(\theta)+ 1= sec^2(\theta)[/itex] and from that, [itex]tan^2(\theta)= sec^2(\theta)- 1[/itex]. That tells me that if I factor out a "4" from that squareroot, getting [itex]2\sqrt{(x/2)^2- 1}[/itex], I can the part inside the square root into a perfect square (and so get rid of the square root) by making the substitution [itex]x/2= sec(\theta)[/itex].
i used the substitution x/2=secu then i reached a point where i got stuck again:
4*integral(1/(cosu)^3) du -4ln(secu+tanu)
so how do i integrate (1/(cosu)^3)??
thank u.
Maybe (sec u)^2(sec u) would help and then maybe integrate by parts, but that probably won't work in the end either.
You could try expanding the fraction by cos u, then using cos^2 u = 1-sin^2, substitution and partial fractions.
Alternatively, use the substitution x=2Cosh(u)
That is cosine to an odd power. "Factor" out a cosine to use with the du and convert the rest (even power) to sine.
Here, the cosine is in the denominator so "factoring" out a cosine gives
[tex]\int \frac{cos(u)du}{cos^4(u)}= \int \frac{cos(u)du}{(1- sin^2(u))^2}[/tex]
Now let v= sin(u) so dv= cos(u)du and you have
[tex]\int \frac{dv}{(1-v^2)^2}= \int \frac{dv}{(1-v)^2(1+v)^2}[/tex]
which can be done by partial fractions.
