How do I know in which direction an object is moving?
  • Context: High School
  • Thread starter Thread starter John Mcrain
    Direction
24 replies · 2K views
John Mcrain
How do I know is this object at rest,moving to the left or moving to the right ?
  • Skeptical
Dale said:
If it were moving left is it at rest? If it were moving right is it at rest? What do you conclude?
If it were moving to the left then is not at rest,if it were moving right than is not at rest...
I think your word order was not quite correct and your question may have been misunderstood. I think the question is, "how can I tell if this object is at rest, moving to the left, or moving to the right".
If you are on a train, what clues are there that you are moving?
My friend look at this object and say: this object can only stay at same position,he said imagine two mens pulls same object with rope with same force in opposite direction,so object must be at rest.
But if this object is plane ,and red force is drag and blue is thrust ,than object moving to the right..
So it seems we don't know from forces vector,what happening with this object..
Is now clear where confusion comes?
A.T. said:
How the object is moving depends on the reference frame you use.
I draw refernece frame origin in my picture
Are you asking about the rest frame of the object, before any forces were applied?
No.
A.T. said:
Are you asking about the rest frame of the object, before any forces were applied?No.
  • Skeptical
You didn't answer my question: Are you asking about the rest frame of the object, before any forces were applied?
Depends on the reference frame.
Just use Newtons 2nd Law. And stop asking about movement without specifying the reference frame. It's a meaningless question.
Because I don't understand your question.
Do you see where is origin on my reference frame in my picture,what else I need to draw?
A.T. said:
You didn't answer my question: Are you asking about the rest frame of the object, before any forces were applied? Depends on the reference frame.Just use Newtons 2nd Law. And stop asking about movement without specifying the reference frame. It's a meaningless question.
Imagine human eyese is at origin of frame and looking at this object..
What happened with this object from human perspective?
Oops, then I misunderstood the question. My apologies @John Mcrain
That is correct. From the forces you only know the acceleration. You cannot determine the velocity from the forces alone. In fact, the object could even be moving up or down.
In order to determine the motion completely in addition to the forces you must also specify the initial conditions: the initial position and the initial velocity.
No.
Object is train and I am at train station looking at this train(object).
What is movement of train(object)?
How is possible to object moves up and down if forces act only left and right?
Initial positon is at this place like its drawn at picture and initial velocity is zero in relation to origin at picture..
If this object is in a car with you and you are driving on the highway at 50 miles/hour, you will say that the object is not moving.
If you are driving on the highway at 50 miles/hour, and this object is hanging from a tree branch on the side of the road, you will say that the object is moving.
How do you know that it is not moving in the first case and is moving in the second case?
If its initial velocity were up then it would continue to move up at the same speed even with forces only left and right.
John Mcrain said:
Initial positon is at this place like its drawn at picture and initial velocity is zero in realtion to origin at picture..
Then it starts at rest and remains at rest. It does not move. Is that clear why? There is no net force to cause it to accelerate. Since it doesn't accelerate its velocity doesn't change. Since its velocity starts at zero and doesn't change then it stays at zero. Since its velocity is zero it is at rest.
Forces produce acceleration, not velocity. That was Newton's key insight over Aristotle.
Ok thanks for answer,so answer on my qestion lie in inital conditions.
So if inital conditions was moving to the right at 100km/h,then object is still moving to the right at 100km/h?
Yes! Exactly
Again we have lotsf post to get answer..
Obviusly my english is so bad?
John Mcrain said:
... initial velocity is zero in relation to origin ...
Then in that frame it will remain zero.
Couldn't they produce the same results by doing this on a moving train?
It's not marked on the diagram so you don't know.
russ_watters said:
This is Newton's first law.
I was wondering why it took so long for someone to quote Sir Isaac.
