How do I minimize a function with a constraint using Lagrange-Euler method?
6 replies · 6K views
fery
I am working on a functional and I need to find its minimum, the conventional procedure is to use Lagrange-Euler method and find the minimum state of the function, but if I need to impose a constraint to the function, I don't know what I need to do
J=int(F(t, f(t), a, b)) minimize(f) and int(G(t, f(t), a, b))=M,
It should be very elementary, but I am confused about what I need to do.
Your help will be very appreciated.
Farshad
I don't understand your notation. See if I've guess the problem correctly:
[tex]J(f)[/tex] is a linear functional defined by [tex]J(f) = \int_a^b F(x,f(x)) dx[/tex] where [tex]F(x,y)[/tex] is a given function of two variables. We wish to find the minimum value of [tex]J[/tex] over all functions [tex]f[/tex] that satisfy [tex]\int_a^b G(t,f(t)) = M[/tex] where [tex]M[/tex] is a given constant and [tex]G(x,y)[/tex] is a given function of two variables.
All true but F(x,f(x)) is a functional not a function, which is mapping of a function to R. For minimization of the functional Euler-Lagrange is the conventional method, but when there is constraint (int(G(t,f(t),a,b)=M) I am not sure what should I do.
Farshad
Then I don't understand the notation F(x,f(x)). If F is a functional and f is a function then
F(f) is a real number correct? We don't need the argument 'x'.
For example, in the calculus of variations an arc length problem is to minimize the functional [tex]J[/tex] given by
[tex]J[f] = \int_a^b \sqrt{1 + (f'(x))^2} dx[/tex]
The expression [tex]\sqrt{1 + (f'(x))^2)}[/tex] is a function not a functional.
I agree, the integrand does not return a number given a function. It returns an expression. You integrate and then you have a number.
You might look up the 'isoperimetric problem' which is an example, or 'variational problems with subsidiary conditions' more generally. Gelfand and Fomin's little book on the calculus of variations has a section on it.
that is, Given the functional:
[tex] J[y]=\int_a^b F(x,y,y')dx[/tex]
let the admissable curves satisfy the conditions:
[tex] y(a)=A,y(b)=B, K[y]=\int_a^b G(x,y,y')dx=M[/tex]
Where K[y] is another functional and let J[y] have an extremum for y=y(x). Then, if y=y(x) is not an extremal of K[y], there exists a constant [tex]\lambda[/tex] such that y=y(x) is an extremal of the functional:
[tex] \int_a^b (F+\lambda G)dx[/tex]
That's from the text and probably is enough to get you started.
