How do I perform the attached calculation in Matlab?
9 replies · 11K views
intel2
how can someone do the attach calculation in Matlab?
Read the documentation. The Matlab getting started guide is particularly good, and will teach you how to perform calculations like this and more.
i went through it but i couldn't get to work.. this is what i did:
for i = 0 : 100
for j = 1 : 101
dme = (sum (sum ((i/j)^ 2)+log(sqrt(j))));
end
end
how about this
for i = 0 : 100
for j = 1 : 101
x= (i/j)^2;
y = (j)^.5;
end
end
F = (sum (x)+log(y))
but the answer is not consistent with the mathcad ansr
There are a couple of important things to note.
Firstly, Mathcad is an infamously flaky piece of software. Use it only if you have absolutely no alternative.
Secondly, the answer you've got from Mathcad is incorrect. The actual result of the summation you've given is
[tex]\sum_{i=0}^{100} \sum_{j=1}^{101} \left[ \left(\frac{i}{j}\right)^2 + \log\sqrt{j} \right] \approx 571831.873[/tex]
You can verify this using Mathematica, Maple, Matlab, or your own C/C++/Python code. Again let me stress: Mathcad is absolutely atrocious software. I've seen the source, and it's not pretty. Avoid it like the plague.
Thirdly, to evaluate the sum in Matlab you can do something like the following:
Code:
% First declare and initialize a dummy variable
x = 0;
% Now perform the summation:
for i = 0:100
for j = 1:101
x = x + (i / j)^2 + log(sqrt(j));
end
end
This should leave you with the variable x holding the result. Note that this is neither a particularly efficient nor elegant way of computing such a sum.
Actually the mathcad result is correct. In matlab, log means ln, log10 means log.The answer shoehorn gives is for ln.
so the code is
x = 0;
for i = 0:100
for j = 1:101
x = x + (i / j)^2 + log10(sqrt(j));
end
end
since we r in the topic; how can i plot the attach equation between [-4,4] with a 0.001 interval using matlab
thanks in advance
read the help files, this is quite trivial.
for i=1:3000
x(i)=-4+i/1000;
y(i)=-x^2-4*x-2;
end
for i=3000:5000
x(i)=-4+i/1000;
y(i)=abs(x);
end
for i=5000:8000
x(i)=-4+i/1000;
y(i)=2-exp(sqrt(x-1));
end
plot(x,y);
Tip of the Hat to Emreth ..
the way u wrote x(i) ,, is smart... once again thanks
