How do I remove nitrogen from air?
  • Thread starter Thread starter goony
    Air Nitrogen
The discussion revolves around methods for removing nitrogen from air, exploring various techniques and their feasibility. Participants address both theoretical and practical aspects, including industrial processes and potential applications in automotive contexts.
  • Experimental/applied
  • Some participants suggest cryogenic liquefaction as a method to separate nitrogen from air based on differing boiling points of gases.
  • Others clarify that the process involves phase changes from liquid to gas rather than freezing.
  • There is mention of using chemical reactions to consume nitrogen, though participants express uncertainty about suitable chemicals.
  • Molecular sieves and zeolites are proposed as potential methods for scrubbing nitrogen from air.
  • One participant discusses enhancing combustion efficiency in vehicles by manipulating air composition and suggests using existing vehicle components for this purpose.
  • Another participant raises the possibility of using pressure swing absorption for nitrogen removal, particularly in medical oxygen generation systems.
  • There is a question about the feasibility of compressing and decompressing purified air on a microscale in a lab setting.
  • A later post seeks clarification on removing nitrogen from air at normal atmospheric conditions using air filters.
Participants express multiple competing views on the effectiveness and practicality of different methods for nitrogen removal, with no consensus reached on a singular approach.
Some methods discussed may depend on specific conditions, such as temperature and pressure, and the feasibility of certain chemical reactions is not fully established.
goony
Hi All, Is there a type of airfilter! that will remove nitrogen from AIR??
if not can I force air through water to remove nitrogen?? If not
How do I remove nitrogen from AIR
Please keep it simple as I is STUPID
goony
The typical way is to cryogenically liquefy air, and take advantage of the different boiling points of the different gases to separate them. You're not going to have any luck with a filter.
- Warren
Do you mean that by freezing air the nitrogen removes itself? during the freezing process
goony
No, I mean that nitrogen and oxygen (and argon, etc.) boil at different temperatures. There's no freezing involved, only the phase change from liquid to gas.
- Warren
To explain further, when you cool gases they turn into liquids - just like when you heat liquids the turn into gases (for example boiling water to make steam)
To turn air into a liquid you have to cool it a lot ( -196deg C / -320F ), this takes a serious piece of industrial equipement.
Then because nitrogen and oxygen turn into liquids at different temperatures you can heat the liquid air up until one of them (oxygen first) boils off, you ae then left with nitrogen, as chroot described.
This is called distilling and is exactly the same process as boiling off water to keep the alcohol when making whiskey - that's why they are called distilleries.
On a small scale you could also find some chemical that reaction with nitrogen but not oxygen and have that 'use-up' all the nitrogen in a sample, leaving just the oxygen. I can't think of anything suitable - most things react with oxygen better than with nitrogen.
http://www.nzic.org.nz/ChemProcesses/production/1D.pdf" on zeolites is also useful for scrubbing nitrogen from air as well.
To some extent you may remove nitrogen using molecular sieves.
Edit: looks like chemisttree beat me by 1 minute :frown:
I have been working on a project for some time now. In cars gasoline is wasted because it is not fully atomized. The air mixture is mostly components that are not concentrated enough to ignite (Hydrogen) or inert components that are of no use (Nitrogen). The Oxygen content limits the reaction in it's current percentage.
I've found that if you cool air that the process of simple dehumidification increases the efficiency of the combustion process. If that air is compressed and sent in through a sealed air-fuel mixture chamber there is further efficiency but less than I expected but it's still impressive.
To describe it, think of trying to boil and egg in Colorado and then do one in Arizona. If you measure the energy spent for the outcome that is the result I demonstrated. O.K.- now that I've demonstrated that I passed the 3rd grade here is my question. Is there a way - using components currently on a vehicle (as I have done) to further enhance the oxygen to the engine?
If one were able to safely compress and then decompress purified and dehumidified air would that be possible on a microscale in a lab?
Q1: "How do I remove nitrogen from AIR"
Q2: "Is there a way - using components currently on a vehicle (as I have done) to further enhance the oxygen to the engine?"
The "Pressure Swing absorption" method mentioned above is actually simple enough. it is used in oxygen makers used for medical purposes. It uses a compound called "Zeolite" to absorb (and remove) Nitrogen from air. At some point the compound becomes saturated and needs to be regenerated using heat.
Waste heat from the exhaust and catalytic converter could be used to regenerate the zeolite intermittently. Since it is a cyclic process, you could use 2 or more scrubbers. One would be in use at all times, while the other(s) are regenerating.
The "Pressure Swing absorption" process also involves pressurization of air. As you mentioned, this alone leads to a small increase in efficiency. Combined with pure oxygen, it would be a large increase.
An engine equipped with this system would not produce Nitrogen compounds formed during combustion as air respirated angines do. The expelled nitrogen could be mixed with exhaust gas downstream.
- Warren
my QUES is at WARREN:
hi sir!
How de we remove nitrogen from air at NORMAL ATMOSPHERIC CONDITIONS? ( Usin any air filter?) Pls reply
shall v use LITHIUM COATIN
