How Do Photons Exhibit Wave Interference?
7 replies · 3K views · last reply
free_electron
What is the current interpretation of the interference of two plane waves in the photon picture?
Does a photon still possesses the properties of its plane wave form? What is the meaning of the intensity maxima and minima?
Photon is a quantum particle. So, the propagation of its wave function is described by the Schroedinger equation. If you solve this equation for the double-slit configuration, and if you take the square of the photon's wavefunction in the vicinity of the photographic plate, you'll obtain the same sequence of maxima and minima which is measured in experiment and which is called the interference picture.
The (quantum) mechanism of formation of the interference picture is the same for one photon and for the flux of billions of photons that we normally call the light wave.
Eugene.
Eugene.
Okay, so a single photon exhibits all the maxima and minima simultaneously? What about the photon wavefunction just before and just after the two slits?
There is no consensus for the interpretation. We have phrases like superposition, decoherence, multiple universes, Copenhagen interpretation, hidden variables. These are all interpretations (or refusals to interpret), and arguments on which is best still rage.
If you have access, this is a good paper to read:
T. Marcella, Eur. J. Phys. v.23, p.615 (2002).
Zz.
Of course, just shooting one photon through the slits once you'll not get the interference picture. To get maxima an minima you'll need to repeat this experiment many times. But it seems that each photon "knows" about interference and it has a higher chance to fall into the "maximum" area than into the "minimum" area.
In most optics textbooks you can find a picture of EM wave passing through two slits. The (real part of) wavefunction looks exactly the same. You can also use the Huygens principle to find it qualitatively.
Eugene.
Eugene.
Thanks, all. I would be interested in any reference which solves Schrödinger's equation for a photon going through 2 or more slits. TIA.
You can find discussions of the double-slit interference based on the Huygens principle in any optics textbook. The same arguments are qualitatively valid for photon's wave function satisfying the Schroedinger equation. Also you can take a look at Feynman's books and lectures. It was his favorite topic.
Eugene.
