How do transistors amplify signals?
  • Thread starter Thread starter d logician
    Transistors
Transistors amplify signals by using a small input current to control a larger current from a power supply, creating a larger output signal. This process is similar to how relays operate, where low voltage controls higher voltage. The output gain refers to the amplification of the signal, not the power, which is why it can appear greater than the input. Efficiency in amplifiers is calculated as output power divided by total input power, which remains less than one since the power supply provides more power than what is output. Understanding this distinction clarifies how transistors function in amplification.
d logician
i have no idea how transistors amplify ...how can the output gain be greater than the input gain ? ...efficiency is output/input which can never be greater than one, right?
sorry how can output be greater than input ...not output gain greater than input gain
Do you understand how a relay works? It uses low voltage and low current to switch a higher voltage and higher current. Transistors are similar.
In the case of transistors, a small input current controls the amount of current drawn from a power supply to create a much larger replica of itself at the output. Efficiency in the case of amplifiers is not the output signal divided by the input signal but the output power divided by the total input power from the power supply. The power supply always supplies more power than is available at the output so the efficiency is still always less than one.
  • · Replies 17 ·
