How do we compute an integral with a dot product inside ?
2 replies · 3K views · last reply
mamadou
I was trying to solve a problem involving work , as we know :
[tex]w = \int_{a}^{b} \vec{f}.d\vec{s}[/tex]
but in my problem the path was cyrcular , so how to evaluate this kind of integral ?
Diagram of a circular arc with centre O and radius R, with points A and B on the arc, angle theta_0 marked at the centre, a red square block on the arc, and horizontal wind force F pushing leftward on the right side.
First of all, this is math. Secondly, it is hard to know exactly why are you are not able to do this, because presumably, you should know how to do a line integral by the time you are taking such a course. You also didn't provide sufficient information of the problem.
Assuming that this a "circular" path, and that your origin is at the center of this circular path, then ds is simply the line element of the circle, i.e.
ds = r dθ θ
where θ is the unit vector in the angular direction. Refer to the figure below.
Diagram of a dashed circle centred at the origin of x and y axes, with a radius r drawn from the centre, a small angle dθ between two lines from the centre, and an arc element labelled ds on the circle.
Then your integral limits will be the angles of the two end points.
Zz.
