How Do You Calculate Flow Rate and Heat Transfer in a Semi-Circular Pipe?
The discussion focuses on calculating volumetric flow rate and heat transfer in a semi-circular pipe, addressing both theoretical and practical aspects of fluid dynamics in this specific geometry.
  • One participant presents a formula for volumetric flow rate in a circular pipe and seeks to adapt it for a semi-circular pipe.
  • Another participant emphasizes the need for clarity in symbol definitions and questions the meaning of "semi-circular," suggesting it could refer to different configurations.
  • A later reply clarifies that the semi-circular pipe is a circular pipe with one flat side, confirming assumptions of steady state laminar flow and smooth walls.
  • Another participant inquires about the heat transfer coefficient for convection in a semi-circular pipe, indicating a related but separate concern.
Participants generally agree on the definitions of symbols and the configuration of the pipe, but there remains uncertainty regarding the appropriate formula for flow rate in a semi-circular pipe and the heat transfer coefficient.
The discussion lacks specific formulas for semi-circular flow and heat transfer coefficients, and assumptions about flow characteristics may not be universally applicable.
Individuals interested in fluid dynamics, particularly those studying or working with non-standard pipe geometries in engineering or physics contexts.
nitinhanda
Hi All:
I am trying to calculate volumetris flow rate in a semi circular pipe with a fixed pressure but seem to have problems. I have calculated in a circular pipe as
Q= (Pi (P1-P2) R^4)/8uL
Can anyone comment on how to calculate for semi circular pipes?
Regards
First of all: always write down what the symbols mean. Now I have to guess, and that's not helping. If I make a mistake (because I use other symbols because I live on another continent perhaps) we waste time.
Assuming that
Pi = 3.14 (-)
P1 and P2 = pressure (Pa)
R = radius (meter)
u = Viscosity (Pa*s)
L = length (meter)
Then Q is the volumetric flowrate, in (m3/s), which seems correct.
The next question is: what is "semicircular"?
Does it mean that it was a round pipe (like almost all pipes) and that it's now flat on one side? Or did somebody put a bend of 180 degrees in a normal pipe?
The pressure difference in a pipe depends on the wall-roughness, bends, flowrate (turbulent or laminar flow) and type of fluid, to name a few factors.
I don't see enough information here.
I'm sorry if I just made life more difficult, but I cannot simply give you the other formula like that... because I don't know it (I'd need more info!)
Hi:
I am sorry for not being clear.
Yes you were right in assuming the symbols. The tube was circular but now its flat on one side - so you are right there also. We can assume steady state laminar flow. We are applying a constant pressure and can assume the tube to be smooth. There is no bend in the tube and we can have the answer in terms of "u - viscosity".
Please let me know if you need any other information.
Thanks
Can Anyone please tell me what is the heat transfer coefficient for convection in a semi-circular pipe?
