How Do You Calculate Pressure Drop in a Garden Hose?
  • Thread starter Thread starter Student3.41
    Rate
The pressure drop across a 28.0 m long garden hose with a diameter of 1.30 cm and a flow rate of 0.610 liters/s can be calculated using Poiseuille's equation. The correct formula is ΔP = 8 * η * L * Q / (π * r^4), where η is the viscosity of water (1.003E-3 Pa*s), L is the length of the hose, Q is the flow rate converted to m³/s, and r is the radius of the hose. The calculated pressure drop is 27400 Pa, confirming the application of the equation in this scenario.
  • Understanding of fluid dynamics principles
  • Familiarity with Poiseuille's law
  • Knowledge of unit conversions (liters to cubic meters)
  • Basic mathematics for rearranging equations
  • Study Poiseuille's law in detail
  • Learn about the properties of fluids, focusing on viscosity
  • Explore practical applications of pressure drop calculations in fluid systems
  • Investigate the impact of hose diameter on flow rate and pressure drop
Students studying fluid dynamics, engineers designing fluid transport systems, and anyone interested in practical applications of pressure calculations in hoses and pipes.
Student3.41
A straight horizontal garden hose 28.0 m long with an interior diameter of 1.30 cm is used to deliver water at the rate of 0.610 liters/s. Estimate the pressure drop (in Pa) from one end of the hose to the other. The coefficient of viscosity for water is 1.003E-3 Pa*s.
Thought this was an easy problem, but can't figure out what I am doing wrong.
Given:
L=28.0m
d=0.013m ===> r=0.0065m
Q(Flow Rate)=0.610L/s... when you convert L - m3... 0.000610m3/s
viscosiy=1.003*10^-3 Pas
So, when you rearrange Poiseuille's equation for \DeltaP ...(P2-P1), you get;
(P2-P1)=8(Viscosity)(L)(Q)/piR^4
Ended up getting 27400Pa=(P2-P1).. I figured this was the pressure drop, and this was the way to do this problem but this answer is incorrect.
Help!
Nevermind, got it!
  • · Replies 16 ·
11K
10K
14K
