How Do You Determine Gain and Parameters from a Bode Plot?
1 reply · 12K views
snoweangel27
Transfer function:
G(s) =[tex]\frac{k}{s^{2}+2\varsigma\omega_{n}s+\omega_{n}^{2}}[/tex]
a) if u(t) = cos(2t), find the steady state response
b) determine the values for k, damping ratio ([tex]\varsigma[/tex]), and the natural frequency.
I know how to find the steady state response by finding G(wj) where w = 2 from the input function. However, I can't seem to find the correct values for k, damping ratio, and the natural frequency.
first I found the cut off magnitudes from the bode plot by multiplying the largest magnitude (40) by (1/[tex]\sqrt{2}[/tex], to obtain the magnitude of the cut off frequencies to be approx. 28.28db. and found the cut off frequencies to be 8 and 10.1 rad/sec, which allows the Bandwidth to be determined by subtracting the two cut off frequencies.
I believe the natural frequency should be 10, since it is also the center frequency, and I found the damping ration to be 0.105 by dividing the bandwidth by 2 times the natural frequency. And I think the gain should be 10.
my transfer function
G(s) =[tex]\frac{10}{s^{2}+2.1s+100}[/tex]
when I find the bode plot of this function it looks similar to the provided plot, but the magnitude is off.
It's been a while I've done these, hopefully I'm not terribly wrong here as it's not quite my area of specialty. At least I got the image plotted in Matlab and it is indeed exactly the same.
Anyway, setting s = 0, you immediately see that the low pass gain ought to be k/w_n^2. Yours is 1/10, which, if my math is right, gives -20 dB gain rather than 20 dB as shown in the figure.
Phase -90 is quite special. Use that to get a second relation between the parameters. Finally I'd proceed to check what value and where |G| gets as its maximum to find the third and last relation between the parameters. You ought to get nice integers as answers (well, the damping parameter is a reciprocal of one).
