How do you find the temperature of the boomerang nebula?
  • Context: Undergrad
  • Thread starter Thread starter melodyman888
    Nebula Temperature
The discussion centers on methods for determining the temperature of the Boomerang Nebula, exploring concepts related to black body radiation, Wien's law, and the nature of reflection nebulae. Participants express varying levels of understanding and seek clarification on these topics.
  • One participant questions whether finding the temperature of the Boomerang Nebula is as simple as measuring its wavelength using Wien's law.
  • Another participant suggests that the brightness of the nebula, despite its low temperature, could be due to it being a reflection nebula that scatters light from a central star.
  • A participant explains that the color of an object is related to its temperature and that measuring the overall spectrum is necessary for accurate temperature determination.
  • It is noted that the nebula's visibility is attributed to light reflection rather than its own emission.
  • One participant mentions the use of luminosity and its relationship to temperature, referencing the formula L=σ x 4πr² x T⁴.
  • Another participant highlights the complexity of determining temperature from color and suggests that the method used historically may require prior knowledge of the principles involved.
  • A later reply discusses how light from a star interacts with the nebula, affecting different frequencies and allowing for temperature estimation based on the light's alteration.
  • A link to a paper is provided for further reading on the methods used to determine the temperature of the Boomerang Nebula.
Participants express uncertainty about the methods used to determine the temperature of the Boomerang Nebula, with no consensus reached on a single approach. Multiple competing views on the nature of the nebula and the principles involved remain present.
Participants acknowledge the complexity of the relationship between an object's color and temperature, as well as the need for detailed knowledge of underlying principles to fully understand the methods of temperature determination.
melodyman888
So i have a physics presentation to do on tuesday and i have no idea how to find the temperature of a of objects in space, specifically the boomeran nebula. I did some research and found stuff involving black body radiation, wiens law, and stefan Boltzmann law but i don't really understand it too well.
Some of the things i don't understand:
wiens law states that wavelength(in meters) is equal to 0.0029/temperature(K). so is finding the temperature of the boomerang nebula really as easy as simply searching for the wavelength? is there a mathematical way to find the wavelength?
how can something so cold be so bright?
does the black body radiation curve have anything to do with this?
If none of this is the right approach to finding the temperature, how did they do it?
Any help will be greatly appreciated
thanks, melodyman888
Astronomy news on Phys.org
hi there
welcome to PF
never heard of the boomerang nebula, what is its NGC or IC number ?
it may be a reflection nebula of which a large majority are
BTW DONT post the same question in multiple forum sections
it leads to lots of confusion!
cheers
Dave
Basically the color of a hot object depends on it's temperature... so, yes, it is a matter of measuring the wavelengths of the light the gas gives off. The overall spectrum is usually needed though.
The brightness of the light depends on how big the object is, and how far away it is, as well as it's temperature. You'll find the nebula is exremely big.
Note that the Boomerang Nebula is visible because it reflects and scatters light from the central star, not because it is glowing.
As I said in your other thread, the nebula is a reflection nebula, so it's visible because of the light it reflects scatters, not because it emits light. I'm afraid I don't know how they found the temperature though.
Luminosity, which is a measure of the total output power of a star(unit: Watts) can be used to find the temperature of the surrounding stars. The luminosity of a star is proportional to its radius and temperature raised to the power 4.That is, L=σ x 4πr2x T4
Wien's law, on the other hand is a direct measure of the surface temperature of the star from the peak wavelength λmof the radiation spectrum emitted by the star.That is,
λm x T = 2.90x10-3 m K
Ok this helps guys, still not completely sure how they did it but i will keep trying to figure it out
Thanks, melodyman888
Did you want to know how it was actually done, historically, or the methods by which it is done today?
You have been told two things above:
1. the principles by which is possible to discover the temperature of distant objects;
2. The exact method that was used to discover the temperature of this nebula (the link from post #6).
The trouble with the second is that the description assumes you already have a detailed knowledge of the first.
The relationship between the color an object glows and it's temperature is not a simple one and a lot of work had to go into figuring these things out first.
I think, though, that the descriptions of (1) missed something ... you can also tell the temperature of something that does not glow by how dark it is ... and, specifically, in what way it is dark.
When light from a star shines through a nebula - different frequencies get blocked by different amounts. The amounts depend on what the nebula is made of and the nebulas temperature.
If we know what the light is supposed to look like with nothing in the way, then we can figure out the temperature and composition of the bits of the nebula in the way.
In this specific case:
http://www.sci-news.com/astronomy/science-boomerang-nebula-01493.html
... astronomers used the radiation left over from the "big bang" to do the comparison.
This radiation is much the same from all directions so we know what it is supposed to be.
But where it passes through a cold nebula to get here, it is different.
  • · Replies 20 ·
  • · Replies 70 ·
14K
