How Do You Minimize the Cardboard Needed for a Box with a Square Base?
  • Thread starter Thread starter karisrou
    Area Minimum
The problem involves constructing a cardboard box with a square base and an open top, aiming to minimize the area of cardboard used while maintaining a specified volume of 32 cubic inches. The discussion revolves around the relationships between the dimensions of the box and the surface area formula.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the formulation of the volume and surface area equations, with attempts to express the surface area as a function of a single variable. Questions arise regarding the correctness of substitutions and the process of differentiation.
The discussion is active, with participants exploring different approaches to derive the surface area function and questioning the validity of their substitutions. Some guidance has been provided regarding the differentiation process and critical points, but no consensus on the final outcome has been reached.
Participants are working under the constraints of a homework assignment, which may limit the information available and the methods they can employ. There is an emphasis on ensuring accuracy in mathematical manipulations before proceeding with differentiation.
karisrou
1) A cardboard box of 32in^3 volume with a square base and open top is to be constructed. Find the minimum area of cardboard needed.
Since it has a square base, length and width must be the same, variable b for base.
So volume could be written as: hb^2=32 and surface area as b^2+4bh=min.
Once I get here, I''m not quite sure what to do.
Any help is greatly appreciated!
You want to get your minimum as a function of one variable. Use substitution to make that happen.
Alright cool. I've got b^2 + 128/b^2 = min
Should I take the derivative now?
You might want to make sure that's correct before you take the derivative. You've got h*b^2=32 and you want to minimize b^2+4*b*h. Are you sure that means b^2+128/b^2 should be minimized?
But aren't I supposed to substitute h into b2 + 4bh? and then solve for the critical point? Or would I just take the derivative of that? And then if that's what I'm supposed to do, do i take the derivative in relation to b or h?
You are supposed to do exactly that thing. But are you sure substituting h=32/b^2 into b^2+4hb gives you b^2+128/b^2?
Right, so b2 + 4b(32/b2)
Which simplifies to
b2 + 128b/b2
Which simplifies to
b2 + 128/b
Which simplifies to
b2 + 128b/b2
Which simplifies to
b2 + 128/b
Right. Now take the derivative.
so 2b - 128/b2
and then would you multiply everything by b2 to clear the denominator? giving you 2b3 - 128 = 0
So b = 3rt64
So 4?
Then if b = 4
h must equal 2, per substitution into the original equation.
So then the areas of the sides are 8, and the base is 16, so the total area is 8 x 4 + 16 = 48
Is this right?
It looks good to me. But I've made mistakes before. Never hurts to double check. Seem ok to you?
Yeah, everything looks right. Thanks very much for your help!
Which simplifies to
b2 + 128b/b2
Which simplifies to
b2 + 128/b
It would be a very good idea to work with equations, in part to help keep you focused on what you're doing.
You're trying to minimize the area as a function of b, or A(b) = b2 + 4b(32/b2) = b2 + 128/b
Then when you take the derivative, you get A'(b) = 2b - 128/b2
To find the critical point, you're going to set A'(b) to 0, so 2b - 128/b2 = 0
You can multiply both sides of that equation by b2 to get 2b3 - 128 = 0, and you can then solve that equation for b.
15K
  • · Replies 17 ·
