How Do You Solve a Complex Integral Using Cauchy-Goursat's Theorem?
32 replies · 5K views
Terrell
##\int_{0}^{2\pi} cos^2(\frac{pi}{6}+2e^{i\theta})d\theta##. I am not sure if I am doing this write. Help me out. Thanks!
Let ##z(\theta)=2e^{i\theta}##, ##\theta \in [0,2\pi]##. Then the complex integral above becomes
\begin{align}
\int_{c}cos^2(z+\frac{\pi}{6})dz \quad \text{s.t. C:}z(\theta)=2e^{i\theta}, \quad \theta \in [0,2\pi]
\end{align}
Since ##cos^2(z)## is an entire function and ##C## is a simple closed contour, then by the Cauchy-Goursat Theorem the integral evaluates to zero.
Orodruin said:
##d\theta## is not the same as ##dz##.
Can you please help me out? The class I got into went through the course too brashly, prof had lots of personal emergencies.
This is not restricted to complex analysis. Whenever you make a change of variables in an integral you must not only change the integrand but also you get a Jacobian determinant for the change in the integral measure. In particular, for a single variable integral, if ##x = f(t)##, then ##dx = (dx/dt)dt = f’(t) dt##.
*faceslap*... commonly called u-substitution. What was I thinking.
Orodruin said:
dθdθd\theta is not the same as dzdzdz.
Can you at least give me hints as to how I should go about this? I feel like I should already know this stuff but my math background is very nontraditional.
How would you do the substitution ##x = t^2## in the integral
\int t^3 dt?
\int t^3 dt?
\begin{align}
\int t^3 dt = \frac{1}{2}\int t^2\cdot 2dt &= \frac{1}{2}\int x dx \quad \text{s.t.}\quad dx=2dt\\
&=\frac{1}{2}\frac{x^2}{2}=\frac{x^2}{4}+K \quad\text{such that K is some constant.}
\end{align}
With the original post the most "natural" start for me is let ##z=2e^{i\theta}+\frac{\pi}{6}##. So I then have ##dz=2ie^{i\theta}d\theta##. Which gives me the integral
\begin{align}
\int_{c}\frac{\cos^2(z)}{2ie^{i\theta}}dz
\end{align}
Then I don't know what's next.
You still have ##\theta## left in your integral. Once you have made your substitution you should only have functions of ##z## (or rather, ##\theta## should be considered as a function of ##z##). I would also suggest that your previous ##z = e^{2i\theta}## was easier, but it should not matter for your end result.
Terrell said:
\begin{align}
\end{align}
\begin{align}
\end{align}
If you put ##z = e^{i \theta}## in the above, you will have just about the most famous integral you can ever meet in a complex analysis course.
Note that he used the substitution ##z = 2 e^{i\theta} + \pi/6##, so I would not insert ##z = e^{i\theta}## (I would do the substitution ##z = e^{i\theta}## instead ...).
I was replying to post #1, where he used ##z = e^{i \theta}## and obtained
\int_{c}\cos^2\left(z+\frac{\pi}{6} \right)dz \quad \text{s.t. C:}z(\theta)=2e^{i\theta}, \quad \theta \in [0,2\pi]
As you noted in #2, ##dz## and ##d \theta## are not the same, so the integral above is not quite correct.
In post #9 the OP switched to ##z = \pi/6 + 2 e^{i \theta}## and obtained the integral in (4). If he were to put back ##z## in place of ##\theta## he would get a simple, standard result and so could easily finish the calculation.
Ray Vickson said:
If you put z=eiθz=eiθz = e^{i \theta} in the above, you will have just about the most famous integral you can ever meet in a complex analysis course.
so ##dz=ie^{i\theta}d\theta##.
\begin{align}
\frac{1}{ie^{i\theta}}\int_{0}^{2pi}\cos^2(\frac{\pi}{6}+2e^{i\theta})ie^{i\theta}d\theta\\
\frac{1}{iz}\int_{1}^{1}\cos^2(\frac{\pi}{6}+2z)dz
\end{align}
I don't know the famous integral you refer to, my calc background is very minimal - I didn't really enjoy integrals in contrast to proof writing courses. I don't know where to go from here. Thanks.
You cannot move the z out of the integral. Also, writing 1 and 1 as limits is misleading. You are integrating along a closed path in ##\mathbb C##.
Yes, I know this. I just had to; to emphasize the substitution. Is it a long way to finish from here or is it close?
I cannot approve of this practice. You cannot write something that does not make sense just to emphasize something else. You could have just put it as a denominator for the rest of the integrand.
You talked about the integrand being an entire function in your first post. What about now with the additional factor of 1/z?
Well, z cannot be zero. But I don't think ##z## will ever be zero because ##z=e^{i\theta}##. Right? So I still think it's entire.
On the curve, no. But this is not what it means to be entire. The Cauchy integral theorem rests upon the assumption that the integrand is holomorphic everywhere.
Orodruin said:
On the curve, no.
Why? The curve we speak of is ##e^{i\theta}##, right?
Yes, entire is analytic everywhere which is synonymous to holomorphic.
Orodruin said:
Also, writing 1 and 1 as limits is misleading. You are integrating along a closed path in CC\mathbb C.
So it's better to keep 0 and ##2\pi## as limits?
So is your function holomorphic?
Terrell said:
So it's better to keep 0 and 2π2π2\pi as limits?
It is better to write ##\oint_\Gamma## and specify what ##\Gamma## is.
##\frac{\cos^2(\frac{\pi}{6}+2z)}{iz}## would not be holomorphic because it has an isolated singularity at the origin...? Also, this singularity is inside the curve we evaluate the integrand so this is where I use Cauchy's Integral Theorem, correct?
Orodruin said:
It is better to write ∮Γ∮Γ\oint_\Gamma and specify what ΓΓ\Gamma is.
Now, I see why this is important. Thanks!
Orodruin said:
Exactly. Does your curve enclose the origin?
Yes! :woot:
So can you apply Cauchy’s integral theorem (which only deals with holomorphic functions) or do you need to use a bigger gun (more general theorem)?
Is this bigger gun the "Cauchy Integral Theorem for Derivatives"? I think the regular gun would suffice?
No. The regular gun deals with integrals of holonomic functions and your function is not holonomic (you just confirmed that it has a pole at z=0). The improved gun is a generalisation of the integral theorem and starts with an R.
However, it strikes me now that you may be referring to the Cauchy integral formula rather than the Cauchy integral theorem. You can apply the formula, not the theorem.
What is holonomic? Did you meant holomorphic? I googled holonomic and it exists and it means something else.
Yes, I meant formula - sorry. But, the formula is applicable right?
Yes, it is late here (4 am) and I am suffering from insomnia so not completely alert ...
Yes, you can apply the Cauchy integral formula with ##z_0 = 0##. The more general theorem is the residue theorem.
