How do you solve this integral using the classic mistake method?
  • Context: Graduate
  • Thread starter Thread starter Alexx1
The integral In = ∫(1/((1+x²)ⁿ)dx can be solved using proof by induction for all natural numbers n (n ≥ 2). The established formula is In = 1/(2(n-1)) * x/((1+x²)^(n-1)) - (2n-3)/(2(n-1))*In-1. The discussion emphasizes the importance of correctly applying integration by parts and recognizing that the integral can be recursively defined. Participants suggest manipulating In-1 to achieve the desired form and demonstrate the solution through specific examples.
  • Understanding of integration techniques, specifically integration by parts.
  • Familiarity with mathematical induction principles.
  • Knowledge of calculus, particularly integrals involving rational functions.
  • Ability to manipulate algebraic expressions and recognize patterns in recursive definitions.
  • Study the method of mathematical induction in depth.
  • Learn advanced integration techniques, including integration by parts and reduction formulas.
  • Explore recursive functions and their applications in calculus.
  • Practice solving integrals of the form ∫(1/(1+x²)ⁿ) for various values of n.
Students and educators in mathematics, particularly those focusing on calculus and integral calculus, as well as anyone interested in advanced integration techniques and mathematical proofs.
Alexx1
In = Integral(1/((1+x2)n)dx
For all n ∈ Natural numbers (exclusively 0), n≠1: In = 1/(2(n-1)) * x/((1+x2)n-1) + (2n-3)/(2(n-1))*In-1
Can someone prove this?
Use proof by induction on n, using integration by parts for the induction step.
I've tried it with that methode..
But what do you choose as u and dv?
I've tried it with: u=(1/((1+x2)n) ==> du= (-2nx)/((1+x2)n+1) and dv= 1 ==> v=x
==> x/(1+x2)n + 2n Integral(x^2/((1+x^2)^(n+1)))
How do you integrate: (x^2/((1+x^2)^(n+1)) ?
Let me rewrite your problem in TeX. Prove for all n \in \mathbb{N} and n \geq 2 that
<br /> \int \frac{dx}{(1+x^2)^n} \;=\; \frac{1}{2(n-1)}\cdot\frac{x}{(1+x^2)^{n-1}}<br /> \;\;-\;\; \frac{2n-3}{2(n-1)}\int \frac{dx}{(1+x^2)^{n-1}}<br />
You've noticed that using integration by parts on In gives you an integral with a power of n+1 in the denominator, which you can't simplify. Instead, try expanding In-1 and working with that expression.
I don't know how to do that.. can you explain it to me?
What does integration by parts on In-1 give you? The idea is that you might be able to manipulate it in some way to achieve the desired form, because all the terms turn out to be of the right form.
I absolutely have no idea how to integrate it by parts on In-1..
Think what the expression means! You have n-1 instead of n, so what? n is any number you want anyway. Call it m if that makes it easier.
Is it like: xn-1 = xn*x-1 ?
I know for sure that you are not as stupid as you're making yourself look right now, it's actually a classic mistake: to think the math is over your head and give up the logic and instead blindly follow what people tell you. Enough rant, sorry.
You have already been given the solution. Look
Put a big and fat parenthesis around \int \frac{dx}{(1+x^2)^{n-1}}, or even write it separately. This is the exact same problem! Solve it again and you get an integral with n-2, again and you get n-3, and so on. Try setting n = 3 and do this two times to see the point.
I knew the answer in the beginning! The only thing I have to do is prove it!
Not proving it by filling in a random figure!
I have to solve integral In and the result must be <br /> \int \frac{dx}{(1+x^2)^n} \;=\; \frac{1}{2(n-1)}\cdot\frac{x}{(1+x^2)^{n-1}}<br /> \;\;-\;\; \frac{2n-3}{2(n-1)}\int \frac{dx}{(1+x^2)^{n-1}}<br />
  • · Replies 16 ·
