How does a electric potatoes peeler work?
  • Thread starter Thread starter mrdavide
    Electric Work
The discussion centers on the mechanics of electric potato peelers, specifically how they rotate fruits for effective peeling. Participants note that while the abrasive-cutting plate rotates, the bowl remains stationary, relying on friction for peeling. An industrial method using sodium hydroxide to soften the skin before tumbling is also mentioned. A design engineering student seeks to adapt this mechanism for a home-use fruit polishing machine.
  • Understanding of electric motor mechanics
  • Knowledge of friction and its role in peeling processes
  • Familiarity with abrasive materials used in cutting plates
  • Basic principles of industrial food processing techniques
  • Research electric motor specifications for small appliances
  • Explore the properties of abrasive materials suitable for fruit peeling
  • Investigate the use of sodium hydroxide in food processing
  • Learn about the design principles for home-use kitchen appliances
This discussion is beneficial for design engineers, product developers, and anyone interested in the mechanics of kitchen appliances, particularly those focused on fruit and vegetable processing technologies.
mrdavide
Hey guys. Just a simple question for you
How does a electric peeler work? In particular how is it able to rotate the fruit? The spinning action itself I think is not sufficient…maybe for the friction on the cutting plate? In a potatoes peeler the only part that rotate is the plate with the abrasive-cutting coating, while the bowl is firm…
Any knowledge will be appreciated.
Ciao
Ciao
Much like a mechanical one, except with a motor:
EDIT: I recall seeing a how-it's-made type show where industrial scale peeling was accomplished by using a caustic (sodium hydroxide--lye) to soften the outer layers and then tumble / rub them around until the outer layers rubbed away. You could probably do something similar with other fruits / vegetables.
hey dude. Thanks for the quick reply. I am a design&enginnering student in italy and i am designing a machine which has to rotate fruit (360°) in order to polish it. So i was thinking to use the same mechanism and layout of the potatoes peller to move-rotate the fruit inside. It will be small as well cause has to be used into a house environment.
Thanks
ciao
