How does a magnetic coupling work?
The discussion revolves around the mechanics and applications of magnetic couplings, particularly in the context of transmitting torque through a hermetically sealed vacuum chamber. Participants explore various configurations, potential challenges, and alternative solutions related to magnetic coupling technology.
  • Experimental/applied
  • Some participants suggest that a magnetic coupling could involve a series of magnets arranged in a circle or configured similarly to an electric motor.
  • One participant describes a specific application involving a vacuum chamber and the need to transmit torque to a flywheel, weighing the options of using a seal versus a magnetic coupling.
  • Another participant explains that magnetic couplings transmit torque using magnets on either side of a non-magnetic pressure boundary, noting that the distance between magnets affects torque transmission capability.
  • Concerns are raised about the use of bearings in a vacuum, with suggestions to explore magnetic bearings in conjunction with magnetic couplings.
  • Some participants discuss the potential for variable torque to RPM transformation in flywheel energy storage systems, proposing the use of electrical coupling as an alternative.
  • There is mention of using aluminum discs with magnets for magnetic damping, which leads to a comparison with induction motors and eddy current braking systems.
Participants express a range of views on the design and functionality of magnetic couplings, with no clear consensus on the best approach or configuration. Various ideas and concerns are presented, indicating ongoing debate and exploration of the topic.
Participants highlight limitations related to vacuum conditions, bearing materials, and the specific requirements of their applications, which may affect the feasibility of proposed solutions.
Webbd050
Is it just a series of attracting magnets in a circle?
It rather depends on just what you mean by “a magnetic coupling”.
It could be a series of magnets or it could be constructed more like an electric motor.
We need more context before we can provide a more definitive answer.
Can you provide an example application or a web link to the particular device ?
Basically what i have is a hermetically sealed vacuum chamber but i need to transmit torque via a shaft to and from a flywheel inside. The 2 ways i can see to do this is just having a seal on the shaft which might leak and cause a lot of friction or transmitting the torque through the wall of the chamber via a magnetic coupling but i don't fully understand how they work or whether they are available to buy. could i just construct my own with some neodymium magnet do you think? Thanks for the reply :)
You're correct, a magnetic coupling transmits torque by using magnets on both sides of some pressure boundary.
The magnets can either be set up around a cylinder:
Or around a flat disk:
Obviously there is a non-magnetic pressure boundary that will be placed between the two. The distance between the magnets will dictate how much torque you can transmit for any given application but if you're only transmitting through a wall that has a differential pressure of one atmosphere, you won't have any problems. I've seen them used in applications where the pressure is many hundreds of psi.
You can purchase them off the shelf so I wouldn't try and design your own. Just do a search on magnetic couplings and you'll find all sorts of suppliers.
That great thanks mate :)
The internal flywheel bearings are going to be a problem. Rolling bearings fail very rapidly in a vacuum. Lead dust or silver powder has been used to lubricate ball bearings for rotating anodes in X-ray tubes.
http://en.wikipedia.org/wiki/X-ray_tube#Rotating_anode_tube
Maybe you can combine magnetic bearings with your magnetic coupling.
Thats a good point, i hadn't thought of that. So are you saying the coupling would support it one end and then another magnetic bearing at the other to support that? The system would be in use on a car would using magnetic bearings not lead to the flywheel wobbling after bumps in the road? I was planning to have magnetic bearings central to support the weight of the flywheel without much friction and then ordinary bearings to the sides to stabilise the flywheel but there's still the vacuum problem would ceramic bearings work in a vacuum?
There will need to be some form of variable torque to RPM transformation in a flywheel energy storage system. That may best be done using electrical coupling. By placing a motor/generator inside the vacuum chamber you then only need to get the electrical conductors or the magnetic field through the wall.
By trying to guess what I meant, you may come up with a new and better solution.
I have no simple answer. I can only apologise for playing the Devil's advocate here.
Technology advances when new combinations of ideas are implemented.
Baluncore makes a good point about grease in a vacuum but I guess that begs the question, what vacuum level are you trying to attain? There are a lot of greases that have very low vapor pressure to avoid outgassing. Try google.
yes,
As our experience, it is not easy to do the magnetic coupling, by your own, because of the maching and manufacturing tools. anyway, there are so many supplier online offer http://www.greatmagtech.com/product_cat_list/Neodymium-Magnets-c21605.html and the shaft or steel shell. you can search it online.
the pictures is very
the pictures are vivid and lively.
I was looking into this myself some time ago, and having two stators of magnets seems odd to me, I was thinking more about how it is done as magnetic damping (dampening).
If you have two aluminium discs with magnets fitted to one of the discs on the fact, you rotate one, and the other will follow it, due to the eddy currents generated in the disc.
I have also seen this used for high speed disc breaking in fast cars, as you don't get friction heat, and the higher the speed (rate of change) the more effect happens.
This youtube shows this effect.
You have reinvented the induction motor where a conductive rotor is dragged by a rotating magnetic field. You can achieve the same by using a three phase field winding rather than permanent magnets. With 3 phase AC you can better control the speed and do not need external moving parts.
The energy released while braking still appears as heat in the conductive disc. That is because eddy currents induced in the disc release heat proportional to I2R. The advantage of eddy current braking is that there is no friction material to wear out or burn. The disc can be more efficiently air cooled if there are no hot friction pads insulating it from the air. Changes in disc surface due to contamination, water or changes in the metal are also largely eliminated.
