How does a magnetic coupling work?
12 replies · 11K views · last reply
Webbd050
Is it just a series of attracting magnets in a circle?
It rather depends on just what you mean by “a magnetic coupling”.
It could be a series of magnets or it could be constructed more like an electric motor.
We need more context before we can provide a more definitive answer.
Can you provide an example application or a web link to the particular device ?
Basically what i have is a hermetically sealed vacuum chamber but i need to transmit torque via a shaft to and from a flywheel inside. The 2 ways i can see to do this is just having a seal on the shaft which might leak and cause a lot of friction or transmitting the torque through the wall of the chamber via a magnetic coupling but i don't fully understand how they work or whether they are available to buy. could i just construct my own with some neodymium magnet do you think? Thanks for the reply :)
You're correct, a magnetic coupling transmits torque by using magnets on both sides of some pressure boundary.
The magnets can either be set up around a cylinder:
Exploded view of a magnetic coupling: an internal rotor with alternating N and S magnets, a grey containment shroud, and an external rotor with magnets, shown beside an opposite view of the assembled coupling.
Or around a flat disk:
Two metal magnetic coupling parts on a blue and white radial background: a grooved steel hub with a keyway on the left and a disk with a ring of trapezoidal magnets on the right.
Obviously there is a non-magnetic pressure boundary that will be placed between the two. The distance between the magnets will dictate how much torque you can transmit for any given application but if you're only transmitting through a wall that has a differential pressure of one atmosphere, you won't have any problems. I've seen them used in applications where the pressure is many hundreds of psi.
You can purchase them off the shelf so I wouldn't try and design your own. Just do a search on magnetic couplings and you'll find all sorts of suppliers.
That great thanks mate :)
The internal flywheel bearings are going to be a problem. Rolling bearings fail very rapidly in a vacuum. Lead dust or silver powder has been used to lubricate ball bearings for rotating anodes in X-ray tubes.
http://en.wikipedia.org/wiki/X-ray_tube#Rotating_anode_tube
Maybe you can combine magnetic bearings with your magnetic coupling.
Thats a good point, i hadn't thought of that. So are you saying the coupling would support it one end and then another magnetic bearing at the other to support that? The system would be in use on a car would using magnetic bearings not lead to the flywheel wobbling after bumps in the road? I was planning to have magnetic bearings central to support the weight of the flywheel without much friction and then ordinary bearings to the sides to stabilise the flywheel but there's still the vacuum problem would ceramic bearings work in a vacuum?
There will need to be some form of variable torque to RPM transformation in a flywheel energy storage system. That may best be done using electrical coupling. By placing a motor/generator inside the vacuum chamber you then only need to get the electrical conductors or the magnetic field through the wall.
By trying to guess what I meant, you may come up with a new and better solution.
I have no simple answer. I can only apologise for playing the Devil's advocate here.
Technology advances when new combinations of ideas are implemented.
Baluncore makes a good point about grease in a vacuum but I guess that begs the question, what vacuum level are you trying to attain? There are a lot of greases that have very low vapor pressure to avoid outgassing. Try google.
yes,
As our experience, it is not easy to do the magnetic coupling, by your own, because of the maching and manufacturing tools. anyway, there are so many supplier online offer http://www.greatmagtech.com/product_cat_list/Neodymium-Magnets-c21605.html and the shaft or steel shell. you can search it online.
the pictures is very
Exploded view of a magnetic coupling showing the internal rotor with alternating N and S magnets, a containment shroud, and an external rotor with magnets, labelled, next to an assembled opposite view.
Two metal cylindrical parts on a blue-white radial background: a steel hub with a keyway bore and set screw in front, and a disc with a ring of dark trapezoidal segments behind it.
the pictures are vivid and lively.
I was looking into this myself some time ago, and having two stators of magnets seems odd to me, I was thinking more about how it is done as magnetic damping (dampening).
If you have two aluminium discs with magnets fitted to one of the discs on the fact, you rotate one, and the other will follow it, due to the eddy currents generated in the disc.
I have also seen this used for high speed disc breaking in fast cars, as you don't get friction heat, and the higher the speed (rate of change) the more effect happens.
This youtube shows this effect.
You have reinvented the induction motor where a conductive rotor is dragged by a rotating magnetic field. You can achieve the same by using a three phase field winding rather than permanent magnets. With 3 phase AC you can better control the speed and do not need external moving parts.
The energy released while braking still appears as heat in the conductive disc. That is because eddy currents induced in the disc release heat proportional to I2R. The advantage of eddy current braking is that there is no friction material to wear out or burn. The disc can be more efficiently air cooled if there are no hot friction pads insulating it from the air. Changes in disc surface due to contamination, water or changes in the metal are also largely eliminated.
