How does a parsec relate to the age of the univers?
  • Context: Undergrad
  • Thread starter Thread starter TalonD
    Age
The discussion revolves around the relationship between parsecs and the age of the universe, specifically addressing the distance to the Cosmic Microwave Background (CMB) and the implications of using parsecs as a unit of measurement. Participants explore the definitions and calculations related to parsecs, light years, and the CMB.
  • Some participants express confusion about the definition of a parsec, with one noting it is approximately 3.26 light years.
  • One participant argues that the distance to the CMB is not accurately described as 13.7 giga parsecs, stating that the CMB does not have a specific distance due to the nature of the universe's expansion.
  • Another participant explains the historical context of the parsec, relating it to parallax measurements and the Earth's orbit.
  • There is a claim that the CMB redshift is commonly given as 1090, leading to a calculated distance of approximately 46 billion light years, which can be converted to about 14 billion parsecs.
  • One participant finds a coincidence in the numerical similarity between the age of the universe and the distance to the CMB when expressed in parsecs, suggesting it is merely a coincidence.
  • Another participant emphasizes that the CMB radiation is all around us, suggesting a conceptual understanding of distance in relation to perception.
Participants express differing views on the interpretation of the distance to the CMB and the use of parsecs as a unit of measurement. There is no consensus on the exact relationship between the age of the universe and the distance to the CMB, with multiple competing views remaining.
Participants highlight that the distance to the CMB is not straightforward and depends on definitions and interpretations of cosmological measurements. The discussion reflects uncertainty regarding the implications of using parsecs in this context.
This discussion may be of interest to those exploring cosmology, astrophysics, and the definitions of astronomical units, as well as individuals curious about the relationship between cosmic distances and the age of the universe.
TalonD
The age of the universe is 13.7 gyrs. The distance to the CMB is 13.7 giga parsecs, maybe I don't understand what a parsec is. Can someone explain?
Space news on Phys.org
A parsec is a unit of distance 3 *10^16 m, or about 3,1 light years.
The distance to the CMB isn't really 13.7GPa - there isn't really a distance to the CMB.
At the start of the universe everywhere was at one point, as it expanded it cooled and after about 0.5M years it was cool enough for matter-radiation to separate, the CMB is the remains of that radiation. that was about 13.7Gyr ago and the photons have been traveling since then as the universe expanded, so they have traveled 13.7G lightyears (or around 4.2GPa) but that doesn't mean the CMB is that distance away.
TalonD said:
... maybe I don't understand what a parsec is. Can someone explain?
Heh... you might get several explanations. Here's wikipedia
http://en.wikipedia.org/wiki/Parsec
A parsec is 3.26 lightyears. Conceptually it goes back to 1838 the first determination of the distance to a star by a guy named Bessel, who used trig with the diameter of the Earth's orbit as a baseline for a long skinny triangle. Or maybe it was HALF the diameter---something like that.
You know the surveyors trig technique where you measure out a baseline and then you sight a distant tree or marker from each end of the baseline, and the angle of bearing is just slightly different. The difference angle is called parallax.
You experience a parallax angle when you stretch your arm straight out and look at your thumb from now your left eye and now your right eye. In that case the baseline distance is the distance between your two eyeballs.
So you asked what is a parsec? It is the distance from which the radius* of the Earth's orbit would subtend an angle equal to one arcsecond (that is 1/3600 of a degree)
*more precisely not the radius, because it's an oval, but half the major axis of the ellipse. It's also called an AU or astronomical unit.
Wikipedia has a diagram that makes it clear, so I won't belabor it. Parsec is short for PARallax angle equals one arcSECond.
If the distance between your eyes was one AU, and your arm was one parsec long, and you squinted at your thumb with one eye and then the other, your thumb would appear to jump by an angle of 1/3600 of a degree---that is by an angle of one arcsecond.
It is just an accident that a parsec is about 3.26 lightyears, and a meaningless accident that 13.7 times 3.26 equals 44.7 which is nearly equal to the 45 or 46 we give for the current distance to the matter that emitted the light we are now getting as CMB.
If the Earth orbit had a different radius, or if the babylonians had divided the circle up into 490 degrees instead of 360 degrees. Or if Bessel in 1838 had used an angle measure different from seconds of arc (1/3600 of a degree), then the parsec would have turned out to be an altogether different distance
TalonD said:
The distance to the CMB is 13.7 giga parsecs...
Not exactly, but close. The CMB redshift is commonly given as 1090.
If you put z=1090 into Wright's calculator, it gives you the today distance to the matter which emitted the light we are now getting as CMB.
It says 45.65 billion LY, but you can round that off to 45 or 46.
OK strictly speaking that is not the "distance to the CMB". The distance to the CMB is zero, it is all around us. It is radiation and some of it is in this room.
46 billion LY is the distance to the MATTER that emitted the CMB radiation that we are currently receiving.
Technically, 46 billion LY is called the distance to the "surface of last scattering".
But as far as I'm concerned calling it "the distance to the CMB" is fine. I know what you are trying to say: the current distance to the source matter.
Now let's take 45.65 and divide by 3.26 to convert to parsecs. I get 14.00 billion parsecs. So I don't get 13.7 like you say, I get 14.0.
Either way it doesn't mean anything, just accidents involving an antique unit still used by astronomers, perhaps out of a sense of tradition.
Here is another good explanation of parsec that I found
http://www.wisegeek.com/what-is-a-parsec.htm
Ok, now I understand what a parsec is. I had kind of an inkling before. so I wondered instead of light years how far away is the CMB in parsecs so I put into the google calculator 45 billion light years in parsecs and it gave the answer 13.7 giga parsecs. and of course I said wow, that's the same as the age of the universe. :P so just a wild coincidence, but I had to ask!
Marcus, I like what you said about the CMB haveing a distance of zero. Very well put. The only perception any of us have of anything is by our 5 senses. All of which require zero distance. It is indeed the matter that produced the CMB radiation that is now 45gly away approximately. But you knew what I meant. ;)
---- Merry Christmas everyone
or for those of you who don't believe... Merry big bang quantum fluctuations...
  • · Replies 20 ·
  • · Replies 18 ·
  • · Replies 18 ·
  • · Replies 39 ·
  • · Replies 16 ·
