How does a the vertical force of gravity end in horizontal motion?
The discussion centers on the phenomenon of horizontal motion resulting from a vertical stream of water, specifically attributing this to radial pressure differences. Participants illustrate the concept using the analogy of squishy rubber balls that deform upon impact, leading to lateral motion due to pressure exerted during the bounce. The conversation also touches on the atomic interactions that contribute to macroscopic pressure differences, emphasizing the importance of boundary conditions in determining droplet movement.
  • Understanding of radial pressure differences
  • Basic knowledge of fluid dynamics
  • Familiarity with atomic interactions in physics
  • Concept of boundary conditions in physical systems
  • Research the principles of fluid dynamics and pressure differentials
  • Explore the concept of boundary conditions in physics
  • Study atomic interactions and their effects on macroscopic properties
  • Investigate the behavior of fluids upon impact and deformation
Students of physics, fluid dynamics researchers, and anyone interested in the mechanics of fluid motion and pressure interactions.
Boltzman Oscillation
When a stream of water falls perfectly vertical, some water hitting the surface will disperse horizontally. What is the force that causes this? References would be awesome!
Radial pressure difference.
To help you see why the reply by @A.T. is correct, you can picture two squishy rubber balls, dropped side-by-side touching each other. When they impact the ground at the same time, they both deform during the bounce and bulge outward on the sides. This causes the two balls to push on each other during the bounce, causing them to bounce apart instead of straight back up.
:smile:
:smile:
Wow that really helped me understand the concept. Now when I searched for radial pressure, I only found engineering topics. Is radial pressure not encountered in a physics curriculum? How would this apply to water? Do the individual atoms bounce apart from each other too?
On the atomic level that's what happens. On the macroscopic level we use the concept of pressure which is the average result of all this bouncing.
I would prefer to express it as Radial external pressure differences.
In other words, among others, It is the boundary conditions that determine the movement of the droplet, or of the parts of it.
The OP asks about a stream of water, not a droplet. The question is, as far I can see, about the initial horizontal acceleration of the water, not about droplet formation.
Ohhh, i didn't noticed that.
I any case, it is just a variant of the same question.
  • · Replies 25 ·
