How does a two open ended pipe resonate?
  • Context: Undergrad
  • Thread starter Thread starter iScience
    Pipe
The discussion revolves around the resonance of air in open-ended pipes, comparing it to closed-end pipes. Participants explore how sound waves behave in these different configurations and the implications for standing waves and resonance.
  • Some participants question how air inside an open-ended pipe can resonate, contrasting it with closed-end pipes where sound reflects off the closed end to create standing waves.
  • One participant suggests that the presence of antinodes at the open ends is essential for resonance, but questions why this must be the case.
  • Another participant argues that while antinodes at open ends are typical, it is not strictly necessary for resonance to occur.
  • A detailed explanation is provided regarding pressure dynamics at the open ends of the pipe, suggesting that antinodes must be located at the ends due to pressure considerations.
  • One participant notes that changes in acoustic impedance at the ends of the pipe lead to reflections, which contribute to resonance, but also mentions that resonance is generally more efficient in closed pipes compared to open ones.
  • There are suggestions to look up additional resources on open-end air columns, with some participants discussing the reliability of various online sources.
Participants express differing views on the necessity of antinodes at open ends for resonance, with some agreeing on the reasoning while others remain uncertain. The discussion does not reach a consensus on the implications of these dynamics for resonance in open-ended pipes.
Participants highlight that the understanding of resonance in open-ended pipes may depend on specific assumptions about pressure dynamics and wave behavior, which remain unresolved in the discussion.
iScience
For a pipe with both ends closed, with sound being produced from one end, sound is reflected off of the other end and is able to produce a standing wave, however, for pipes with both ends open or one end open, how can the air inside this pipe resonate? or is it not really there air inside that is resonating? is it the pipe itself that is resonating?
Look up open-end air columns.
it only tells me that there must be antinodes at the open ends it doesn't say why. i understand why there cannot be antinodes at the end of a closed end, but why does it have to be an antinode at an open end?
That is the whole point of resonance.
It does not have to be.
But it is physically possible.
And if there is something that comes close, it will be there.
...Whaaaaaaat?
can you put context behind everything you just said i did not follow..
Let's consider the the left-hand end of an open-ended tube oriented horizontally. Suppose that end were not an antinode. Then there are two possibilities:
1) The pressure a bit to the left, outside the tube, is even higher than the pressure at the end.
2) The pressure a bit to the right, farther into the tube, is higher than the pressure at the end.
#1 doesn't make a lot of sense; that would have the pressure outside of the tube, where it is free to expand up and down as well as sideways, higher than the pressure inside the tube where it can only expand sidewise.
#2 looks more plausible, but by the argument above the pressure just outside the tube cannot be higher than the pressure just inside the tube, so a higher-pressure region inside the tube will want to move to the left.
So #1 says that you can't have an antinode outside the tube; #2 says that the antinode nearest to the end of the tube but still inside the tube will want to move towards the end of the tube (antinodes deeper in the tube are being pressed from both sides so tend to stay put). Put them both together and you end up with the antinodes right at the end of the tube.
so basically the pressure is highest at the ends right?
You cannot have an antinode outside the tube because the pressure outside the tube radially degrades and so you cannot make a standing wave out of this. which means obviously that whatever standing waves that exist have to exist inside the tube. is this right? it seems rather obvious now but just wanted to check if this is the right line of reasoning
Yep - that's the right line of reasoning.
At each end of the pipe there is a change in acoustic impedance (in the pipe and in the open air). Wherever there is a change in impedance when a wave propagates, there will be some reflection. Sometimes there is a phase inversion and sometimes not. If the distance between the discontinuities in impedance (the ends) is the right value for constructive interference (waves travel in both directions and be 'in step'), there will be a build up of energy stored in the column. That is what resonance is.
The reflection of energy at a closed end is more efficient than at an open end, as it happens, and the resonance is not so good with open ended pipes as with closed pipes.
Where?
Did you consider an internet search engine?
What search engine does Physics forums suggest for physics explanations and advice?
PS...dont want to stray to far away from the original post !
Google works just fine for this, although as with any internet search you still have to separate out the good sites from the plausible-sounding crap.
Some wikipedia pages are good, some are awful. If you get into the habit of looking at the discussion page as well, you'll generally get a pretty decent sense of how trustworthy/mainstream a given page is. The references and external links on a wikipedia page are often more valuable than the page itself.
(I'm wondering if we shouldn't fork a new thread for this discussion)
You can imagine a short 'plug' of air in each end of the tube. Because the ends are open there is little restraint on these 'plugs' moving in and out. Their movement will send pressure variations along the tube from each end and here is where you have the essentials of resonance.
2 waves traveling towards each other (from each end of the tube)
The one condition that must be satisfied is that the (open) ends of the tubes are antinodes.
Look at Google images for open tube resonance for some great illustrations.
Hope this helps
The Hyperphysics pages are a good source of info on most topics. Pretty reliable stuff, too but not always a lot of chatty explanations. Wiki is usually ok on the basics. Check back with PF to confirm what you have understood is pukkah.
26K
  • · Replies 16 ·
